I am using the Emporia Vue 2 Energy Monitor along with the Home Assistant Integration for Emporia Vue Energy Monitor by Magico13 via HACS. I have tuned the monitor so that it shows the same daily kWh usage values as reported by my electric company. I then used the Utility meter helper in HA and created peak and offPeak tariffs and switch them out daily based on the Time of Used program I am on. The tariffs use the sensor *** Home 1,2,3,1D which is the emporia daily usage sensor as the source. Why are the tariff sensors reporting almost 22% higher totals than the source sensor. Below is a screenshot showing the different between the emporia sensor and the tarrif sensors. The grid total should match the Home sensor.
