cure1245
(Chris)
November 22, 2022, 1:43am
1
Recently my energy dashboard has been acting funny: the graph shows the correct scaling and information, but the bars themselves have completely disappeared!
Even data that was already there has completely disappeared.
Any thoughts on what’s going on?
GertJan
November 22, 2022, 9:08am
2
Same here. Graph scaling is correct, sensor data is correct, but no bars are displayed !
cure1245
(Chris)
November 22, 2022, 3:26pm
3
How long has it been happening for you?
daer-71
(Daniel Eriksson)
November 23, 2022, 9:26pm
4
Same problem here. Scale correct, kWh value correct, but no bars.
I have had this problem for the last two versions.
cure1245
(Chris)
November 24, 2022, 3:21pm
5
Which type of install are you folks using? I’m using Docker.
Slinkos
November 24, 2022, 3:30pm
6
I’m using docker too, no problems at all. Running the version 2022.11.4
cure1245
(Chris)
November 24, 2022, 3:38pm
7
I created a bug report: if anyone else is experiencing the issue, please follow the link and let them know!
opened 03:35PM - 24 Nov 22 UTC
### Checklist
- [X] I have updated to the latest available Home Assistant versi… on.
- [X] I have cleared the cache of my browser.
- [X] I have tried a different browser to see if it is related to my browser.
### Describe the issue you are experiencing
I am reading my energy meter's AMR signal using an SDR that reports to an MQTT broker. About a week ago, the bar graphs showing usage per time period are no longer appearing, although the graph scaling and amounts below the graph are accurate:
![image](https://user-images.githubusercontent.com/4430996/203820251-a11c6ebe-ffc4-4ac8-acee-fa5fd4a82126.png)
Here's a picture of the raw meter sensor:
![image](https://user-images.githubusercontent.com/4430996/203820858-ef1f280e-d070-4555-a662-eb709238af90.png)
### Describe the behavior you expected
I expect there to be bars showing on the graph.
### Steps to reproduce the issue
1. Use MQTT to connect an energy meter entity
2.
3.
### What version of Home Assistant Core has the issue?
Home Assistant 2022.12.0.dev20221124
### What was the last working version of Home Assistant Core?
_No response_
### In which browser are you experiencing the issue with?
All broswers
### Which operating system are you using to run this browser?
Any OS
### State of relevant entities
_No response_
### Problem-relevant frontend configuration
_No response_
### Javascript errors shown in your browser console/inspector
_No response_
### Additional information
_No response_
daer-71
(Daniel Eriksson)
November 27, 2022, 3:20pm
8
Updated to the latest version, 2022.11.4 (running in Docker), and my bars are back.
Restored a backup and my bars are also back. Don’t know what de problem was…
cure1245
(Chris)
December 13, 2022, 9:06pm
10
Just updated the docker image a couple hours ago and they’re gone again…
I reopened the GH issue.
