Hello
I’m trying to setup my solar panels in HA, but keep failing ![]()
After digging through the documentation and forums, I’m still stuck with getting the data from Ahoy DTU added to the energy dashboard.
Right now I have the error message:
Entity not available
The state of this configured entity is currently not available
sensor.hm_1500_solar_inverter_daily_yield (unknown)
These are my config files:
#AhoyDTU Hoymiles1500
- state_topic: "inverter/Hoymiles1500/ch0/YieldDay"
name: "HM-1500 Solar Inverter Daily Yield"
value_template: "{{ value | round(2) }}"
unit_of_measurement: "Wh"
device_class: energy
state_class: total_increasing
- state_topic: "inverter/Hoymiles1500/ch0/YieldTotal"
name: "HM-1500 Solar Inverter Lifetime Yield"
- state_topic: "inverter/Hoymiles1500/ch0/P_AC"
name: "HM-1500 Solar Inverter Current Yield"
value_template: "{{ value | round(0) }}"
unit_of_measurement: "W"
state_class: measurement
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
media_player: !include media_players.yaml
# Example configuration.yaml entry
adaptive_lighting:
lights:
- light.adaptive_lichter
mqtt: !include mqtt.yaml
template: !include template.yaml
The MQTT broker shows this:
2024-05-07 16:21:55: New connection from 172.30.32.2:33204 on port 1883.
2024-05-07 16:21:55: Client closed its connection.
2024-05-07 16:23:55: New connection from 172.30.32.2:48172 on port 1883.
2024-05-07 16:23:55: Client closed its connection.
2024-05-07 16:25:55: New connection from 172.30.32.2:34162 on port 1883.
2024-05-07 16:25:55: Client closed its connection.
2024-05-07 16:27:55: New connection from 172.30.32.2:58394 on port 1883.
2024-05-07 16:27:55: Client closed its connection.
2024-05-07 16:29:55: New connection from 172.30.32.2:42334 on port 1883.
2024-05-07 16:29:55: Client closed its connection.
but according to this it should be normal.
I added the SQL statistics data manually, since the were missing as well…
Can someone point me in the right direction?
