kecktus
September 5, 2022, 1:56pm
1
Hello, I have a problem with the energy dashboard. I have included two entities there. Now I wanted to add a third one, unfortunately it is not displayed.
In my opinion, however, this is identical to an existing one:
The entity “Strom (Keller)” is displayed, but “Strom (DB)” is not.
Does anyone have an idea where the error is?
HasQT
(Has)
September 6, 2022, 12:26am
2
State_class: measurement.
Energy dash only takes state_class: total increasing there.
kecktus
September 6, 2022, 11:02am
3
Okay thanks. I fixed that, but unfortunately the entity is still not displayed. I also restarted HA and cleared the browser cache.
Was it wrong to just adjust the state_class via the developer tools? Is there another way?
HasQT
(Has)
September 6, 2022, 11:49am
4
^ you mean you just changed it here?
Yeah that won’t work it’s not a permanent change.
It depends on the device abit…
how is your device configured?
If its the same as the strom keller… You need to add the state_class to the setup.
or you may have to use customise yaml.
it depends…
kecktus
September 6, 2022, 12:21pm
5
Okay, yes there I changed it.
The Devices are Utility Meters from the helpers section. That’s why I’m also surprised that they differ.
Is there a way to override the state_class simply via the configuration.yaml?
HasQT
(Has)
September 6, 2022, 1:10pm
6
I would tend towards re-adding it via utility meter.
If that doesn’t work, I think that customize yaml file still works.
sensor.strom_db:
state_class: total_increasing
