Energy Dashboard not updating after update despite entities updating
After updating HA to 2024.12.2 (and now on 2024.12.3) and ESPHome, my energy dashboard is not showing any new data for the Energy Usage or Individual devices detail usage. I can confirm that the entities are correct, and if I drill into them in History the historic data is there and new data is still flowing in correctly. The energy dashboard Grid distribution and Sources are updating as expected. Any idea what is causing the dashboard to no longer update? Thanks!
Check devtools/statistics for issues.
I’ve got the same issue, I tried 2024.12.[1,2,3] but ended up back on 2024.11.3.
All my energy reporting devices were failing to show up in the Energy dashboard. They span, Matter, WiFi (TP-Link Tapo), Zigbee (ZHA) and none showed up.
Has any tracker issue been found for this?
As an update, Energy reporting appears to be fixed in 2024.12.4 but I don’t know which change/fix did it.
