I’ve been scratching my head as i had some bogus / dead sensors in my energy dashboard but could not remove them through the UI. I took an editor and access to \config .storage\energy to remove the dead nodes. Would be great if you can delete them as well through the UI.
Hello Frank, thanks for your prompt reply. Unfortunately when i search for energy configuration, i end up in the same panel where i can’t edit/remove the dead sensors.
If you look towards the bottom of the list on the right, you can see your missing sensor with a different icon, just click the bin icon to remove it from your energy devices list
Edit: Solved it. Turns out the Bosch sensors never obeyed the rename entities I selected when I renamed the device a good while back, they are the culprits as that plug has currently dropped connection to HA at the moment.
Actually you are right Woempiej! After carefully examining the issue again (i changed some sensors around) indeed. The yellow is only an error and the entity can be deleted in the list like normal. Thanks!!!
