Hi all,
In my HA instance, I have configured a rooted Toon thermostat as source for the energy dashboard. The Toon is connected to the P1 port of my smartmeter, which provides the data of electricity usage/production and gas production. This gives multiple sensors in HA, which are added to the energy dashboard configuration at the sections “Grid consumption”, “Return to grid” and “Gas consumption”.
The Toon thermostat is only working for this data, it is not used anymore as thermostat. Therefore, I want to replace the thermostat solution in HA with a P1 cable, directly connected to HA.
This cable is already connected to the smartmeter (together with the Toon thermostat) and provides new sensors in HA with the same data as the Toon does.
If I remove the Toon sensors from the energy dashboard configuration and replace them with the new sensors, I loose all historic data of the Toon sensors. If I keep the Toon sensors and add the new sensors next to them, all data is shown double.
Is there any way to make the desired switch while retaining the historic data?
