Energy Dashboard Sensor Help
I finally got my power monitoring integrated into HA using some help from this thread.
The problem I have now is that I have an entity that tracks net power usage and goes negative when I returning power to the grid. The energy dashboard doesn’t like this negative value and I cannot figure out how to create a new sensor so it will read properly. I tried making it so when it was a negative value it turned positive and a positive value reported as 0. This worked but I could not use the sensor in the energy dashboard.
The code I have for the sensors currently is
Sensors.yaml
  - platform: integration
    source: sensor.net
    name: Net Back to Grid
    unit_prefix: k
    round: 2
Rest Sensor in Config.Yaml
- name: "Net"
        value_template: "{{ value_json.net }}"
        device_class: power
        unique_id: curb-14
        unit_of_measurement: W
Every variation I have tried that
will give me a positive value in kWh but will not allow me to select it in the energy dashboard.
I can use sensor.net_back_to_grid in the energy dashboard but because its a negative value it messes up the calculations.
Can anyone help me out? ChatGPT can only get me so far as my coding knowledge is laughable.
Have a read of this thread.
Are you using CURB’s to calculate your energy generation?
Here’s my code to convert CURB’S Solar Generation Watts Sensors to positive:
### CONVERT CURB VALUE TO POSITIVE FOR SOLAR CT 1
    sensors:
      solar_panel_1_positive:
        value_template: "{{ states('sensor.curb_solar_panels_1') | int(0) | abs }}"
        friendly_name: 'Solar Panel 1 Power Generation'
        unit_of_measurement: 'W'
### CONVERT CURB VALUE TO POSITIVE FOR SOLAR CT 2
    sensors:
      solar_panel_2_positive:
        value_template: "{{ states('sensor.curb_solar_panels_2') | int(0) | abs }}"
        friendly_name: 'Solar Panel 2 Power Generation'
Here’s my code too sum each of the CT into 1 sensor:
### SUM SOLAR CT 1 + SOLAR CT 2
    sensors:
      energy_solar_total:
        friendly_name: "Solar Total Power"
        device_class: power
        value_template: "{{ states('sensor.solar_panel_1_positive') |float + states('sensor.solar_panel_2_positive') | float }}"
As you can see by my sensor I have 2 CT Clamps for measuring each leg of the breaker box feeding energy to the grid/house. If you want the sensor to show as energy (kWh) and not as power (W) you can create another sensor like this:
### CURB Energy Riemann sum integral ###
    source: sensor.solar_total_power
    unit_prefix: k
    round: 2
Let me know if you need any help if this does not work for your setup.
I hobbled some stuff together from your code and what I had so its now working.
I am using curb to calculate my energy generation. Curb outputs a variable Net, Consumption (total power being used), and Solar(although I am using my solaredge inverter to report this info as I already had it setup). The NET variable tells me how much power I am using from the grid (positive value) and how much power I am returning to the grid (negative value). So I made a sensor that reports any negative value of NET as return to grid and any positive value being from grid.
I am sure there is a more elegant way to make this work than the spaghetti I wrote but it seems to work.
Thank you very much
solar
