I have an Enphase system and everything was setup and has been working fine for 6 months or so. Then a few days ago the Enphase Component stopped working on me. It did not seem like there had been anything that had changed with the component, but could not get it to work. Removing the custom component and re-adding it fixed it somehow.
I changed the entity names to what they were previously so I did not have to change things on the dashboards.
The one thing that is acting odd and I cannot work out is the Energy Dashboard. For the Grid Import Power and Grid Export Power, it is not showing the numbers in the underlying entities. To make it more confusing, the “cost” column does seem to be calculating based on the underlying correct values.
Can anyone explain what I am missing that is causing this?
