I recently started to tinker with ESPHome. Works great! Neat feature.
I noted that my Energy dashboard started to become sluggish, so I started to suspect the SD card on the RPi 3+.
Nevertheless, I had to remove the EPSHome integration for another reason and all of a sudden the Energy Dashboard was working again! Both the ESPHome Add-on and the Integration had been removed.
Today I got new ESP32’s and started to tinker again. I compiled and ran the ESP32 (ESPHome) from my PC. Home Assistant found the ESPHome, and the integration was enabled again. The add-on is not installed.
All of a sudden, the Energy Dashboard was extremely slow again!
Changing days takes around 7-8 seconds. Normally it’s immediate.
I also notice quite a degradation when looking at history. The longer time you look for, the worse it gets. Looking at 7 days of sensor data takes 20-30 seconds to display.
Home Assistant 2022.10.5
Supervisor 2022.10.0
Operating System 9.2
Frontend-version: 20221010.0 - latest
ESPHome: Version: 2022.10.0
My ESPHome code is super-simple:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
ota:
password: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Solar Hotspot"
password: "solarhotspot"
captive_portal:
font:
# gfonts://family[@weight]
- file: "gfonts://Roboto"
api:
encryption:
key: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
- platform: homeassistant
entity_id: sensor.electricity_price_karlskrona
internal: true
i2c:
scl: GPIO25
sda: GPIO26
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.print(0, 22, id(roboto), "Hello");
Kindly guide me in a direction to understand what is happening, and how I can prevent this. This sadly makes ESPHome useless for me, and do love the feature!
EDIT: The behavior is the same with the ESPHome on-line (turned on) and off-line (turned off).
EDIT2: ESPHome integration now removed again. After reboot the system is back to normal. Performance degradation of my system is caused/correlated to the presence of ESPHome
Thanks, Marcus
