Energy Dashboard unable to select solar power
I’m trying to get solar power in the Energy dashboard, but its not appearing in the drop down menu.
I can add a Sensor card to a custom dashboard and select solar power.
I’m using SolarEdge cloud integration for solar power.
Any ideas?
Just to make sure there is no confusion, the Energy Dashboard will need an energy sensor (power is not supported). I have not kept up with the latest requirements, but if you have a Solar Edge sensor with units in kWh (and Wh appears to now also be supported), device class of “energy”, and state class of “total_increasing”, then it should appear in the pulldown menu.
Thanks I’ll have a look.
