I’m just trying to set up the Energy Dashboard.
I added both of my SMA Inverters and later a battery inverter (Just waiting for the password).
Now Im getting a ton of sensor readings from them but I really don’t know which are the right ones?
I got a sensor reading for metering_total_absorbed which is the same in both Inverters, it measures the Total energy that I received from the grid. So I added this to the Grid consumption tab. Same for metering total yield which is the total energy I supplied to the grid. I was not even able to select other values they didn’t show up. I guess its correct then? The values need are the total supplied or received kwH right?
Is it the same for my solar panels? Cause I can only select their total produced kwH.
I also added all sensors that I used to the recorder. But only for 7 days. Is there a way to just safe specific values longer than the others in a database or something?
For now it just looks like this:
