Hi everyone,
Stupid question: on a fresh instance of HA, I can see the energy dashboard and a wizard to configure it.
On my production instance, I want to add this same functionality (dashboard + wizard), but can’t see where. What am I missing?
I suppose this has something to do with my configuration.yaml:
# GLOBAL CONFIG FILE
homeassistant:
# Name of the location where Home Assistant is running
name: PvO4 (hass-86)
# Location required to calculate the time the sun rises and sets
latitude: 50.867461
longitude: 4.707878
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 28
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Brussels
# Customization file
customize: !include customize.yaml
# zie https://community.home-assistant.io/t/please-help-automation-for-ikea-tradfri-remote-control-e1524-e1810/142707/2
packages: !include_dir_named packages
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
# enables Lovelace YAML mode
# lovelace:
# mode: yaml
# Enables custom python scripts (see https://www.home-assistant.io/integrations/python_script/)
python_script:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
# api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- 172.30.33.0/24 # ip adres van nginx container
- 192.168.4.0/24 # ip adres van netwerk
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# Tracked history is kept for 10 days
recorder:
purge_keep_days: 10
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Example configuration.yaml entry
logger:
# default: critical
# default: warning
default: critical
logs:
# log level for HA core
homeassistant.core: critical
# log level for MQTT integration
homeassistant.components.mqtt: warning
# log level for all python scripts
homeassistant.components.python_script: warning
# tuya integration
tuya: warning
# SENSORS
# display the current Home Assistant versions
- platform: version
# Weather prediction
# - platform: yr
# Text to speech
tts:
- platform: google_translate
service_name: google_say
# Cloud
# cloud:
# System Health
system_health:
# mobile app
mobile_app:
# WEBHOOKS
webhook:
# INCLUDES
# group: !include groups.yaml
group: !include_dir_merge_named groups
# group dir: !include_dir_merge_list groups
automation dir: !include_dir_merge_list automations
#script: !include scripts.yaml
script: !include_dir_merge_list scripts
# scene: !include scenes.yaml
scene: !include_dir_merge_list scenes
How can I add this energy dashboard?
Kind regards!
Bart
