Hello. I’m trying to use the “Energy” feature. I’m trying to configure Grid consumption (Configuration / Energy / ADD CONSUMPTION). Power is obtained from an mqtt sensor relaying power. I keep getting “No Matching statistics found” in the Consumed Energy (kWh) drop down. My confg:
- platform: mqtt
state_topic: emonpi/power
unique_id: emonpi_power
state_class: measurement
device_class: power
# unit_of_measurement: "W"
- platform: integration
source: sensor.emonpi_power
unit_prefix: k
round: 6
This is the arrangement that I’ve seen reported elsewhere as working, but it’s not working for me.
Many thanks. There is no entity sensor.power_use on my system. I changed it in case there was some magic behind the scenes, but it still shows “No matching statistics found”.
Check the state of what? Both sensor.power_use and sensor.energy_use are available and registering data. Neither are available as a source of statistical data for grid consumption configuration. I appreciate your time, and admire brevity as much as anyone, but your comments are a little too cryptic for me to follow. Thank you again, though
- platform: mqtt
unique_id: power_use
device_class: power
unit_of_measurement: W
source: sensor.power_use
unit_prefix: k
round: 6
is, in Developer Tools / State Attributes, generating this for sensor.energy_use:
state_class: total
unit_of_measurement: kh
friendly_name: energy_use
icon: mdi:chart-histogram
device_class: energy
I’ve no idea why unit_of_measurement is kh, not kWh as in your example, but I’m guessing that’s why it can’t find an energy statistic. Do you know what I’m doing wrong?
- platform: mqtt
name: Power Use A
unique_id: power_use_a
device_class: power
source: sensor.power_use_a
unit_prefix: k
round: 6
Another solution it’s to edit database. Cannot help on that.
state_class: total
unit_of_measurement: kWh <------ :)
friendly_name: energy_use_a
I think that fixed it. I could select sensor.energy_use_a. It’s currently reporting that “statistics_not_defined”, but I assume it’s currently aggregating and this will become available.
