Energy export Daily/monthly sensor disappers and appears sometimes
Hello from Vienna,
as written in my previous post the issue that above mentioned sensor are not available at all, is solved. Data are available and so far so good. But …sometimes a.m. sensors are not available:
grafik
It can be seen on the graph too:
grafik
In the log file I see many inputs like:
grafik
As a beginner I cannot interpretate these behavior as in general the data I’m getting seems to be very accurate.
Is this something what I have to accept or is a change at my configuration necessary?
thx for your help
Now it’s available…
grafik
It could be many things, but it’s hard to say without knowing which integration provides those sensors. It could be an issue with the integration (so check the open issues for that integration) or you have a (local) network issue.
If you are using the core Shelly integration make sure to enable CoIoT (unicast).
https://www.home-assistant.io/integrations/shelly/#shelly-device-configuration-generation-1
e4264b43d684669fb14abc298676bbe9df62df91_2_452x500
After successful network change (fixed IP address installed), I have completed your recommendation. Will report later about improvements
THX
Rudi
obviously this was the the hint I missed. Now it works as it should be! thx
