I just integrated my solar into home assistant. The numbers looks fine: 6.9kWh is what I produced today, 2.8 is what used and the remains part goes to grid:
However, as you can see the “energy stream” (as indicated by the moving dot on the line) always goes from solar to grid and then from grid to Home.
But I think as long as the usage is less than Solar production, the flow to Home should always be from Solar, not from Grid.
Why is this?
EDIT: maybe my entities are not assigned properly in the energy dashboard settings.
My Enphase Envoy integration gives me two energy entities: Lifetime Energy Production and Lifetime Energy Consumption.
The former I put into “Return to Grid” and “Solar Production” is this not what it’s supposed to be?
