Energy from individual devises sumary
Hi
I have an issue with energy from some devices. (Miele)
The kWh is messured in a Way where i reports 0.1kwh then 2 kWh and 4kwh and so on.
Next session same result. So this displays Way more than real usage.
This is graphed 0.1+2+4 = 6.1 and not 4kwh.
This is the case for dryer and dish wascher, but not washer.
Is there a Way to change this ?
state_class: total_increasing
unit_of_measurement: kWh
device_class: energy
friendly_name: Tumble dryer Energy
Thanks for helping
Erik L
Perhaps you could show us the actual graph that does this bogus summing. The history graph of your sensor could also be useful.
That is correct for an energy (kwh) sensor.
Thank, i have investigatet more and the issue seems to be a 0 if connection is not ok, then it register wrong.
I Will make a filter to address this. And se if this correct it. (Not using the dryer Daily :grinning:)
Regards Erik
