That’s nice, now I have to wait for more integrations can be used with this. I receive my grid consumption from influxDB sensor. Wich is not compatible… I don’ want to go back to mqtt
After setting up, is there a way to walk through the setup again ? It isn’t calculating the way it should so I would like to keep trying sensors until it makes sense.
Unfortunately several of my Powerwall sensors are not available in the dashboard yet.
Cool, got it setup now. It became only clear after first sensor, you could actually add more sources for consumption and returning energy. I used my monthly values from utility meter as somehow my guts say, if I use daily, it might end-up with some issue where the utility meter and the energy management integration reset values at slightly different times.
My energy meter is basically a FHEM server with an IR reading head connected to my eHZ Smart Meter which talks SML and delivers all the values. I send these decoded values to Home Assistant via MQTT, so what do I need to change to make it report as capable?
See MQTT Sensor documentation and make sure as much data as possible is provided: last_reset_topic, last_reset_template, state_class, device_class, unit_of_measurement, and anything else you can provide.
Great stuff! Only at the moment I can’t add any of my entities for grid consumption or return to grid since I’ve custom sensors made using an API. In the dropdown list the sensors are not listed.
This new ‘Energy’ stuff looks cool!
Did take some effort - everything in my home is based around power (kW) rather than energy (kWh) so had some help to get the necessary sensors connected through an ‘integration’ sensor.
Would be cool to see power handled directly in future, avoiding that extra complication when getting set up - looking at some comments here, it seems to be a common barrier to easy use!
This seems to be the key - set up a new ‘integration’ sensor with your kW sensor as the source, and this new sensor should slot right into the Energy stuff!
This is something I’m very interested in but there’s something I don’t quite understand. On my Energy page, the red-orange-green gauge that says “Returned to grid” does not show the same value as the Energy distribution card. I can confirm that the data in the Energy distribution card is correct because it shows the same data as my (template) sensors. Can anyone explain this or how the gauge is calculated? Also I don’t get any calculated costs even though I set prices but that’s not a big deal.
Some suggestions to make these awesome new features even better if you’ll take them:
Update energy view more than once per hour
Let us use template sensors
Include gas usage
Thank you for this awesome addition. This is what I’ve been trying to achieve for a long time!
[EDIT]
I noticed the gauge combines what I used from the grid and what I’ve returned. That’s fine but in that case I think the title is a bit misleading/unclear.
