It would be good to get some setup documentation for this. If I use my Fronius feed for solar it just assumes my house is consuming it rather than a mix of battery and house, so I’m trying the Powerwall feeds.
Currently I am trying:
Home Battery Storage
Energy going into the battery: Powerwall Battery Import
Energy coming out of the battery: Powerwall Battery Export
Solar Panels
Solar production energy: Powerwall Solar Import
Electricity grid
Grid Consumption: Powerwall Site Import
Return to Grid: Powerwall Site Export
Individual devices Powerwall Load Export
Not sure if this right or wrong… won’t know for 2 hours or so…
I do have these concerning messages down the side of the energy dashboard:
Grid neutrality could not be calculated
Self consumed solar energy couldn’t be calculated
Consumed non-fossil energy couldn’t be calculated
I have a small fv power plant with a battery. I don’t understand how to use Shelly EM to monitor the battery as recommended. Shelly EM works with AC voltage. It will not work on DC. How do you handle the situation?
If anyone has an Enphase Envoy, I’ve written a python script to obtain Consumption and Production data directly from the Envoy, so no need to rely upon getting the data from the cloud or to use the built-in HA integration. The resulting sensors display power/voltage/power factor/frequency and current once per second so can also be used to drive real-time power monitoring panels.
The idea is that you monitor the AC power/energy put into/ taken out of the battery system. ie: on the AC side of the inverter that the battery system runs through
It’s not very good for me. I use several battery-powered devices and the inverter won’t detect them. It will probably be a better solution to use ESPhome, nodemcu and PZEM-017
Are you using PW2 with the energy dashboard? I’m just trying to share my experience and contribute. There doesn’t seem to be any documentation specific to this available yet.
Someone can tell me, please, how the CO2 signal integration works?
I’m using the new panel with CO2 signal together now for almost a week and it says every day, that i only get around 18% of green energy every day.
My contract with the Dutch company Eneco is Hollandse Wind & Zon, that states, that 100% of my energy is green.
So i can imagine, that the current flows thru Europe are different, than what the business side of it is. It looks, like CO2 signal does not take any account in, how the energy is buyed in.
Or, my contract with Eneco is a big screw…
Anyhow, it is weird, knowing, I bought 100% green in, and get only 18% according to CO2 signal.
+1 for the daily fixed charge request. In the UK it’s normal to have a daily “standing charge” in addition to the per unit charge (just to complicate comparing suppliers )
