hello I need help.
I want to build a flow for node red that calculate and send through mqtt energy consumption of my house measured in my shelly pro 3 em.
anyone can help me?
ok i make this… it works well but anytime I reboot node… it resets
any help?
"id": "d207741a429718f0",
"type": "debug",
"z": "9bfd23d692c499bb",
"name": "debug 5",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 820,
"y": 420,
"wires": []
"id": "fce69fa3d3263b3d",
"type": "server-state-changed",
"name": "Consumo Bocchio",
"server": "e8e7fd0.247eb",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.consumo_bocchio_total_active_energy",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 1,
"output_only_on_state_change": true,
"for": "0",
"forType": "num",
"forUnits": "seconds",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 130,
"y": 300,
"wires": [
"42c09cf1dd9c7fb3"
"id": "42c09cf1dd9c7fb3",
"type": "change",
"name": "w",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.values[0].value_scaled",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 310,
"y": 300,
"wires": [
"d51a1863a0f12473",
"152feed774c6238f",
"998a795ca7707563",
"822f6e5d67b41022"
"id": "822f6e5d67b41022",
"type": "change",
"name": "set current",
"rules": [
"t": "set",
"p": "energy",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 450,
"y": 220,
"wires": [
"id": "e7f6f16d64d9c2b8",
"type": "inject",
"name": "newday",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "00 00 * * *",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 100,
"y": 380,
"wires": [
"fe3228d4b16feb32"
"id": "fe3228d4b16feb32",
"type": "change",
"name": "set day start",
"rules": [
"t": "set",
"p": "day_start_energy",
"pt": "flow",
"to": "energy",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 260,
"y": 380,
"wires": [
"d51a1863a0f12473"
"id": "d51a1863a0f12473",
"type": "function",
"name": "calc consumption of today",
"func": "if (!flow.get(\"day_start_energy\"))\n flow.set(\"day_start_energy\", flow.get(\"energy\"));\n \nmsg.payload = flow.get(\"energy\") - flow.get(\"day_start_energy\");\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 500,
"y": 380,
"wires": [
"0c6d421057b64e20",
"9de67151a098a892",
"d207741a429718f0"
"id": "0c6d421057b64e20",
"type": "ui_text",
"group": "d15c50bb.6b0f38",
"order": 2,
"width": 0,
"height": 0,
"name": "Consumo Giornaliero",
"label": "Consumo Giornaliero",
"format": "{{msg.payload | number:3}} w",
"layout": "row-spread",
"className": "",
"x": 780,
"y": 380,
"wires": []
"id": "9de67151a098a892",
"type": "function",
"name": "consumption to cost",
"func": "let Z = 0.93; // Fattore di Conversione\nlet H = 11.3; //Valore kWh / Nm³\nlet c = 14.32; // Cent / kWh\nmsg.payload = msg.payload * Z * H * c / 100;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 480,
"y": 460,
"wires": [
"f2abe5e1e9897481"
"id": "f2abe5e1e9897481",
"type": "ui_text",
"order": 3,
"width": 0,
"height": 0,
"name": "Costo Giornaliero",
"label": "Costo Giornaliero",
"format": "{{msg.payload | number:2}} €",
"className": "",
"x": 710,
"y": 460,
"wires": []
"id": "152feed774c6238f",
"type": "ui_text",
"order": 1,
"width": 0,
"height": 0,
"name": "Meter",
"label": "Consumo Totale",
"className": "",
"x": 670,
"y": 300,
"wires": []
"id": "0bfb070013fe1234",
"type": "debug",
"name": "debug 6",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 820,
"y": 560,
"wires": []
"id": "e5bf56c4febdc08d",
"type": "inject",
"name": "newweek",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "00 00 * * 1",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 90,
"y": 520,
"wires": [
"7dedcff47a14e1f5"
"id": "7dedcff47a14e1f5",
"type": "change",
"name": "set week start",
"rules": [
"t": "set",
"p": "week_start_energy",
"pt": "flow",
"to": "energy",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 270,
"y": 520,
"wires": [
"998a795ca7707563"
"id": "998a795ca7707563",
"type": "function",
"name": "calc consumption weekly",
"func": "if (!flow.get(\"week_start_energy\"))\n flow.set(\"week_start_energy\", flow.get(\"energy\"));\n \nmsg.payload = flow.get(\"energy\") - flow.get(\"week_start_energy\");\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 490,
"y": 520,
"wires": [
"a9106fef21778d3d",
"b24596d515d33f35",
"0bfb070013fe1234"
"id": "a9106fef21778d3d",
"type": "ui_text",
"order": 4,
"width": 0,
"height": 0,
"name": "Consumo Settimanale",
"label": "Consumo Settimanale",
"className": "",
"x": 780,
"y": 520,
"wires": []
"id": "b24596d515d33f35",
"type": "function",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 480,
"y": 600,
"wires": [
"d586ada138db2e61"
"id": "d586ada138db2e61",
"type": "ui_text",
"order": 5,
"width": 0,
"height": 0,
"name": "Costo Settimanale",
"label": "Costo Settimanale",
"className": "",
"x": 710,
"y": 600,
"wires": []
"id": "e8e7fd0.247eb",
"type": "server",
"name": "Home Assistant",
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "",
"connectionDelay": false,
"cacheJson": false,
"heartbeat": false,
"heartbeatInterval": "",
"statusSeparator": "",
"enableGlobalContextStore": false
"id": "d15c50bb.6b0f38",
"type": "ui_group",
"tab": "3c9b4e17.5d49ea",
"order": 7,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "3c9b4e17.5d49ea",
"type": "ui_tab",
"name": "Consumi",
"icon": "dashboard",
"order": 1,
"disabled": false,
"hidden": false
noone can help me?
You’ll want to save the context to the file system.
https://nodered.org/docs/user-guide/context#saving-context-data-to-the-file-system
@Kermit
I applied your suggestions and it wrote a file… on path… /config/node-red/context/9bfd23d692c499bb/flow.json
then I have a function based on previous flow infos… that is:
if (!flow.get("day_start_energy"))
flow.set("day_start_energy", flow.get("energy"));
msg.payload = flow.get("energy") - flow.get("day_start_energy");
return msg;
how to change it to read this file? because it stops working…
You can also use a HA numeric helper to read / store a value.
This persists reboots.
