it happened that I am planning to install some solar panels on my house’s roof.
I need a simple and clean way (without any CT clamps) to measure my house’s electricity usage and instantaneous power.
I was thinking about the module which could be mounted on the DIN rail in my fuse box.
Are there any plug-and-play solutions in the market?
The other ones are nice, but I would prefer a straightforward solution with Wi-Fi. Maybe if there are no other products I will consider using one with Modbus.
EDIT: by the way, maybe there is any wi-fi <-> Modbus bridges that allows easy integration with home assistant?
I would not prefer the tuya devices (this is why I made the recommendation above) - but wanted to list them as an option (personal preferences doesn’t count )
I haven’t seen others based on Wifi - and personally, I would not rely on any similar technology for such devices…
Wifi-Modbus Bridge:
You can try to check the following:
This is a modbus proxy that can be installed on a Raspberry pi… so you could install this within your fuse Box - connect the meter to it… and then connect HA over wifi to the proxy / raspberry
