Energy Module - wrong solar usage in january 2022
Since jan 2022 I have a huge solar consumption, as you can see at the image.
The consumption showed, concerns the accumulated production of my installation.
The question is: how can I set the correct value?
You may want to check Energy Management - full data reset? - #4 by Protechtedd - Configuration - Home Assistant Community (home-assistant.io) for deleting an entire day of your energy stats.
Energy Management in Home Assistant - #455 by markss - Blog - Home Assistant Community (home-assistant.io) describes how to remove certain entries.
