Energy Monitoring and sp120 or tasmota plugs
I tried to configure my energy tab, but I can’t add my innr sp120 or my tasmota plugs over mqtt. …I can only add my Shelly rollershutter.
Can me someone explain how to add the plugs ? In both devices I have a energy entity.
Thx
For your Tasmota plugs, do you use auto discovery or are they defined in yaml ?
I used Auto discovery over mqtt
no one a idea?
I have the same issue and I’ve been searching for a solution for a while now.
Innr SP 120 plug + Zigbee2Mqtt 1.18.1-1 + mqtt auto discovery
Two devices, none of them is listed.
I think it could be due to tha lack of the “state_class” attribute.
That one is more then a year old, long before the energy tab was introduced. You probably still use the deprecated daniel welch repo. Switch to the official repo and install 1.22.2
Thank you!
I wasn’t aware of this change and thought I had all up to date!
Is there anything I should know to substitute the current add-on with the new one?
Should I install the new one before or after removing the old one?
Is it possible to copy&paste the configuration?
EDIT
Stopped the previous add-on (still not removed, just in case…), added the new one and copied the configuration: everything seems to be working out of the box.
Plus now I got the add-on frontend, so I think I could remove the Zigbee2Mqtt Assistant add-on.
Energy Tab configuration now shows my two plugs in the dropdown list.
Thank you!
