Energy Monitoring changes please
I just fitted a shelly EM and started monitoring my power and the feature is great but I have some issues, I would like to be able to re-name the sources as shellyem-98CDAC1E472A channel 1 Energy and shellyem-98CDAC1E472A channel 2 Energy are not very descriptive along with the individual devices part, I realise you can rename the devices but in the past have had issues with Integrations updating and the detected hardware going back to a long generated name.
Also I set up an input_text for the energy cost but because it will only go to 3 decimal places and mine is £0.18981/KWh I originally put it in as pence per KWh instead of pounds and this has resulted in my first days recordings being 100 times too high. Can we have the ability to update past costs, as well as either a higher floating point resolution in text inputs or a way to convert from p/kWh to GBP/KWh.
Cheers
You should rather use an input_number.
You can do it by manipulation your database directly.
Sorry Burningstone, the input text was an input_number it seems to accept the 5 decimal places as the initial value but only shows 3 and only allows steps of 3. I am currently installing SQLite web to have a look in the database.
Cheers
