Energy Monitoring with B+G E-Tech WS100-1943 Energy Meter via ModBus RTU via Waveshare RS485 TO WIFI/ETH
Hi everyone,
just wanted to share a short configuration to get my energy monitor of my car into HASS, as I struggled a bit with the combination (Had to split the post because of some restrictions, all media in the comments below):
Energy Meter: B+G E-Tech WS100-1943 Energy Meter
All Parameters standard
baudrate: 9600
bytesize: 8
stopbits: 1
parity: none
can all be found here: [LINK1] https://stromzähler.eu/media/ee/97/41/1704818760/WS100-19xx_1123_DE.pdf
To hook this up into my LAN I configured the RS485 TO WIFI/ETH as follows:
Converter: Waveshare RS485 TO WIFI/ETH
Documentation can be found here: [LINK2] https://files.waveshare.com/upload/6/61/RS485-TO-WIFI-ETH-User-Manual-EN.pdf
Working Mode to Transparent [IMAGE1]
Uart Settings set to the default from the energy meter: [IMAGE2]
Ethernet settings had to be changed to hook it up to my switch [IMAGE3]
Network A Settings remained mainly unchanged [IMAGE4]
Home Assistant Configuration:
configuration.yaml
modbus: !include modbus.yaml
modbus.yaml
- name: modbus-garage
  type: rtuovertcp
  host: [IP address of the RS485 TO WIFI/ETH]
  port: 8899
  sensors:
    - name: "BGE-Active Power CUPRA"
      device_address: 1
      address: 260
      unit_of_measurement: W
      data_type: int32
      input_type: input
      unique_id: "BGE-260"
      state_class: measurement
    - name: "BGE-Total Fwd CUPRA"
      device_address: 1
      address: 270
      unit_of_measurement: kWh
      data_type: int32
      input_type: input
      unique_id: "BGE-270"
      state_class: total
      precision: 2
      scale: 0.01
Big shoutout to the post of m9aertner here [LINK3]
[IMAGE2]
[LINK3]
[IMAGE3]
[IMAGE4]
Thanks for the shoutout. I now used your post here to read out my GoodWe GW10KN-ET / Pylontech H3 “Battery State of Charge” (SOC) via Waveshare / Modbus Register 37007.
For some reason, this measurement does not show up with all my other GoodWe readings (using the GitHub - mletenay/home-assistant-goodwe-inverter: Experimental version of Home Assistant integration for Goodwe solar inverters integration; probably because the battery power cables are currently disconnected, only the CAN connection is in place?)
In any case, here’s my modbus config snippet:
- name: waveshare1
  type: tcp
  host: 192.168.1.208
  port: 502
  sensors:
    - name: "Battery SOC"
      device_address: 247
      address: 37007
      unit_of_measurement: '%'
      data_type: int16
      input_type: holding
      unique_id: "WAV1-37007"
      precision: 0
