What happened here? I’ve got this kind of problem before on other meters also (gas and power), so it seems to happen from now to then.
Can anybody explain what could caused this and how to repair it? The data comes from an ESP32Home sensor (simple binary counter) and the sensor wasn’t updated since weeks. Is there something wrong inside the ESP or does HA mixed things up?
I’ve got sqlite plugin installed also, if that is needed and i’m also a little bit familar with SQL but got no explanation where this completely wrong values should come from?
This shows statistics and in this case a negative jump from sum-value (example) 300 > 297.2 (i.e a minus of roughly 2.8). Why this happens…beats me, but you are not alone.
Option 1: try to look in the dev tools > statistics and there you can find the sensor that registers this…on the far right there is an icon and you can try to correct the value
Option2: the statistics…this can become tricky depending on where the issue lies. Probably on statistics_short_term that feed into statistics. Without much detail, the field ‘sum’ values have to match what you want. e.g. 300, 302, 305, 305, 306, 309 etc.
If statistics_short_term is off then you have to start there before correcting statistics
In any case, backup first, I would copy the two tables temporarily in the same db. And if this is a sensor delivering belwo a few minutes freq…switch off sensor or HA too
So it appears that your history starts at 13:00 on the 19th. You asked for data back as far as the beginning of the day (0:00) but there is none shown before 13:00.
I’m also having an issue with this.
I was on holiday for a couple of weeks and the ESP Watermeter froze.
Now I’m back, restart the thing and my Energy shows -47m3.
I found out that everytime i restart one of my metering-ESP nodes, e.g. because of an ESP-firmware-upgrade through HA, the node sends the initial consumption, set in the config.
What i do to measure the consumption is
globals:
- id: total_pulses
type: int
#restore_value: true
initial_value: '553313' # set initial counter read from device as decimal (three counts after decimal point included, e.g. if it reads "553.313" write as "553313")
binary_sensor:
- platform: gpio
pin:
number: GPIO5 # "D1"
inverted: true
mode: INPUT_PULLUP
filters:
- delayed_on: 200ms
on_press:
then:
- lambda: id(total_pulses) += 1;
name: "Total water consumption"
device_class: water
unit_of_measurement: "m³"
state_class: "total_increasing"
icon: "mdi:water"
accuracy_decimals: 3
lambda: |-
return id(total_pulses) * 0.001;
I thought “globals” where stored in HA but it looks like i was wrong and they are only inside the node itself. So as part of an firmware-upgrade the old initial value will we reset. Maybe this is also the case if there was a powerloss or reboot of the ESP node.
