Energy-Pass Gauge in Energydashboard
(for eurepean users) it would be helpfull if there was a way to see the energyefficence rate of the house/ appartement direct in the energydashboard to see if some measures take effect.
This only applies to users wich use fossil-energy for heating. Other energy wich is used for heating (e.g. heat-pump) can be ignored.
To calculate this you only need the energy messurements in kWh of the year and the living space in m². Then it is possible to calculate the needed energy per m².
For example: To heatup 200 m² there were 15.000 kWh needed. Now 15.000/200 = 75 kWh/ m² which leaded to efficience level “C”. ( <= 30 A+; <= 50 A; <= 75 B; <= 100 % C; <= 125 D; <= 150 E; <= 175 F; <= 225 F; > 225 H).
To had this in place this were the perfect addition to the self-consumption and autarky-grade.
