[{"id":"f5c93860d9e2cc95","type":"comment","z":"5303158a.06509c","name":"Solar Temperaturdifferenz","info":"https://discourse.nodered.org/t/simple-maths-flow-to-create-difference-between-two-temperature-sensors/54898","x":150,"y":3420,"wires":[]},{"id":"bd8a6a7755706190","type":"poll-state","z":"5303158a.06509c","name":"Solar RL Temp","server":"f16080ab.5b606","version":2,"exposeToHomeAssistant":true,"haConfig":[{"property":"name","value":"Solar Maximumwert"},{"property":"icon","value":"mdi:water-minus"}],"updateinterval":"1","updateIntervalType":"num","updateIntervalUnits":"minutes","outputinitially":false,"outputonchanged":false,"entity_id":"sensor.solar_ruecklauf_temperature","state_type":"num","halt_if":"","halt_if_type":"num","halt_if_compare":"is","outputs":1,"x":140,"y":3460,"wires":[["53a1d7f8ea5d12a9"]]},{"id":"42209b803712c507","type":"inject","z":"5303158a.06509c","name":"temp a","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"24","payloadType":"num","x":130,"y":3520,"wires":[["53a1d7f8ea5d12a9"]]},{"id":"e22c8c4e1c1ab1c7","type":"inject","z":"5303158a.06509c","name":"temp b","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"26","payloadType":"num","x":150,"y":3580,"wires":[["e8e4602ac984bed4"]]},{"id":"a2acb7deb2d45375","type":"poll-state","z":"5303158a.06509c","name":"Solar VL Temp","server":"f16080ab.5b606","version":2,"exposeToHomeAssistant":true,"haConfig":[{"property":"name","value":"Solar Maximumwert"},{"property":"icon","value":"mdi:water-minus"}],"updateinterval":"1","updateIntervalType":"num","updateIntervalUnits":"minutes","outputinitially":false,"outputonchanged":false,"entity_id":"sensor.solar_vorlauf_temperature","state_type":"num","halt_if":"","halt_if_type":"num","halt_if_compare":"is","outputs":1,"x":140,"y":3640,"wires":[["e8e4602ac984bed4"]]},{"id":"53a1d7f8ea5d12a9","type":"change","z":"5303158a.06509c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"tempA","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":3520,"wires":[["2a08dedd252d1246"]]},{"id":"e8e4602ac984bed4","type":"change","z":"5303158a.06509c","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"tempB","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":3580,"wires":[["2a08dedd252d1246"]]},{"id":"2a08dedd252d1246","type":"join","z":"5303158a.06509c","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":570,"y":3540,"wires":[["30cd17c6bc4cf0c2"]]},{"id":"30cd17c6bc4cf0c2","type":"change","z":"5303158a.06509c","name":"Differenz Solar zu Speicher","rules":[{"t":"set","p":"payload.TempC","pt":"msg","to":"payload.tempA - payload.tempB","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":3540,"wires":[["52481d56f95a5b5b","eca53bd30b9f8de7"]]},{"id":"52481d56f95a5b5b","type":"debug","z":"5303158a.06509c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1050,"y":3500,"wires":[]},{"id":"eca53bd30b9f8de7","type":"switch","z":"5303158a.06509c","name":">=3 Grad","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"2","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1080,"y":3580,"wires":[["7d1f91d9bb1fd69a"]]},{"id":"f16080ab.5b606","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]![NodeRed Temp difference|690x167]
got it solved
Finding the temperature difference and then saying “less than” → turn pump off.
