Energy sensor/template
Hi there,
I have a smart plug coming, im planning to connect it to zigbee2mqtt.
I want to create a template which shows the used energy consumed in Euros. Reading a lot of topics…I should be able to get it done, but I’m not sure of a couple things.
-1ste I make a integration called utility_meter, on the entity of the smart plug, but which one? In the documentation I see two options.
  • Power, measurement in W
  • Energy, measurement in kWh
Think I need the"energy"?
2th the integration makes a new sensor, this is the sensor that I need for the template I guess?
3th I have to created a whole new “sensor template” whit the entity of the sensor that the utility_maker created?
The code that I need to change the output from W or kWh to euro… it’s all abba kadabra for me :roll_eyes:.
Do I miss something? Any feedback is appreciated :sweat_smile:
Link for documentation
Correct. The one in units of kWh.
Also correct. You can make more than one. So you could have energy per day and energy per month.
Correct. Three in a row! :star:
If you need help with the template sensor just ask.
Tom, thank you for the confirmation and the :star: LoL.
So when I make a daily and a monthly, I will get 2 sensors if I’m correct, and need to make 2 templates to display then separately?
The only thing I won’t get is the code… It’s JSON or something :roll_eyes: could you point me in the right direction?
I want to manipulate/change the output from kWh to euro.
Yep all correct again, except it’s Jinja not JSON.
You’ll want something like this for each:
    sensors:
      daily_energy_cost:
        friendly_name: "Daily Energy Cost"
        unit_of_measurement: '$'
        value_template: "{{ states('sensor.your_daily_utiliy_energy_here')|float * states('input_number.cost_per_kwh')|float}}"
The use of an input number allows you to easily adjust the cost per kWh if/when it changes:
cost_per_kwh:
  name: Cost per kWh
  mode: box
  min: 0.00000001
  max: 100.00000001
  unit_of_measurement: "$/kWh"
  icon: mdi:currency-usd
The stupid precision is because of this issue:
Thank you again, that Jinja code is what I need , I saw something about “round 2” inside the Jinja code, as far I understand… That is for the decimals?
Is it still needed for the “mode box”? I have a fixed energy plan for years so I guess I won’t need to update it a lot.
For the template, when I add more… For example monthly, I don’t need to start on a new line right? I can start monthly_energy_cost: under the last line?
When the template is done, I can select it as a sensor in UI as a sensor card to show up
Sorry for all this questions, but I want to be prepared… Because of my work, I only have the weekends to short and try this things out.
It is, see updated template below to round to 2 decimal places.
Then you can just replace it with the number (e.g. $0.29 per kWh):
    sensors:
      daily_energy_cost:
        value_template: "{{ ( states('sensor.your_daily_utiliy_energy_here')|float * 0.29 )|round(2) }}"
        friendly_name: "Monthly Energy Cost"
        value_template: "{{ ( states('sensor.your_monthly_utiliy_energy_here')|float * 0.29 )|round(2) }}"
See above.
Yes you can.
Wooh great, thank you. . Much appreciated.
Tomorrow I will be home, I dive straight into it!
Thank you.
All great information, thank you both!! I want to do something like this one of these days, now I don’t have to figure it out myself.
as promised I’ve dived in to it, everything works fine… but on the template a get a error.
property unit_of_measurment is not allowed.
thus is the code that I have add the moment:
    sensors:
      daily_energy_cost:
        friendly_name: tv wand daily
        unit_of_measurement: '€'
        value_template: "{{ ( states('sensor.daily_energy')|float * 0.21632 )|round(2) }}"
        friendly_name: tv wand monthly
        value_template: "{{ ( states('sensor.monthly_energy')|float * 0.21632 )|round(2) }}"
edit:
I saw I forget the " sensor" on top, I added it. but now I get a error: " missing property “platform”
this is the code right know.
    sensors:
      daily_energy_cost:
        unit_of_measurement: 'kWh'
also I changed the unit of measurement to ‘kWh’ I’m not sure what it as to be? € or kWh?
post the full error, not an abridged version
the error is only showing in RED letters in visual studio code, when I copy and paste the code the RED error is not showing her?
is your visual studio code setup to detect errors properly? Personally, I wouldn’t rely on it. That’s what config checker is for. Check your config and see if there’s errors.
Also, when you reply to a person, use the reply on the persons post, not the blue button at the bottom of the topic. Thanks.
@petro
thx for you’re feedback, when I check the config I get the error to. how can I show that error line from the config check?
just copy/paste it
@petro
I hope you mean it like this:
Controleer je configuratie als je onlangs wijzigingen hebt aangebracht en zeker wilt weten dat ze geldig zijn
Ongeldige configuratie
CONTROLEER CONFIGURATIE
Invalid config for [binary_sensor.template]: [unit_of_measurement] is an invalid option for [binary_sensor.template]. Check: binary_sensor.template->sensors->daily_energy_cost->unit_of_measurement. (See ?, line ?).
Yes, it’s telling you that unit_of_measurement is not valid for the binary_sensor section.
@petro
oke, i understand that. my English understanding is better than I can wight it LoL…sorry.
but what’s wrong, I have copied the code that I get from Tom, and replace the stuff that I needed.
in some other topics I saw the same type of measurements put in?
binary_sensor can only be on or off. unit_of_measurement is only valid for sensors, not binary_sensors.
@petro
so do I need to make a separate sensors.yaml !include? and put the template under that one then? will that short it out?
