For whole house energy consumption monitoring, I have two PZEM-016 sensors, one clamped on each leg my split phase power feed coming into my breaker panel. These devices are modbus, which is supported natively by Home Assistant. I purchased one of the PZEMs with an included RS458->USB converter to poll the modbus nodes within home assistant.
I can give more details if anyone is interested, but it’s a pretty uncomplicated installation.
So, I have two PZEM-016s, I have the one CT from each clamped into the main incoming feed in my breaker box.
I have the CT wires extended so I can place the PZEM outside my breaker box. I then have them both plugged into an outlet in the vicinity.
I have a modbus loop going from one, to the other, then to a RS485->USB converted plugged into my HA server (as a daisy chain).
From there, the modbus component is used to pull in the sensor data from each register.
The modbus RTU component seems to have some timing issues at the moment, so it creates a pretty noisy log, but it never seems to actually create any issues in the data that gets read in.
I’ll assume this was directed at me, but if not just ignore it lol
No real updates, It’s been working great for months so I haven’t touched it much lol.
I saw you mention you are now using a RS485 to TCP/IP modbus gateway?
Yes, I’m now using a USR-W610 bridge to take the RS485 signal to Modbus TCP/IP over wifi. The USR-W610 can do a lot actually, with RS232 or RS485, WiFi or ethernet, etc, but I’m keeping it simple in my setup.
an you comment on that part as my electrical panels are in a utility room that does have a ethernet switch; but not a physical host.
So I was hoping to daisy chain 6 of the PZEM-16 off the modbus to monitor […]
If you have wifi there, you could use the W610 to take in the serial signal and let HA consume it over the network. Daisy chaining modbus isnt a problem. The PZEM-16s all come from the factory with the same node address, so I would recommend using a USB<->serial adapter (RS485) to connect it to your laptop and change the node address on each one to be unique. It’s not too difficult and the PZEM manual actually does a decent job explaining the register map.
Ha, I’m not sure how much detail there is!
I have 2 PZEM-016s, which I configured separately to have unique node addresses. Each with a split core CT over one of the incoming phases. The modbus connection of one is daisy chained to the second, which is chained to the USR-W610’s RS485 port. The W610 is connected to my WiFi network. Home Assistant is configured to read the W610’s IP address as a modbus TCP/IP node. This is the configuration inside HA for the modbus network:
I can’t remember why the port isn’t the standard modbus TCP/IP port (502), maybe I changed it in the W610 configuration. I’m not home now to check.
Hi. I also have some PZEM-016 and am using an Elfin RS485 to WiFi serial server. I am reading the values into HA with no issue. However I would like to send a reset command to zero the kWh counter each month. I can do it using MBPoll by sending hex string “01 42 80 11” where 01 is the device address and 42 is the hex command to reset energy (as per the PZEM manual). The 80 11 is the CRC check.
Do you (or anyone else out there) have any idea how I can write this command.
Thanks.
Hm. How many modbus devices do you have?
I have bought USR-TCP232-419 (Ethernet to RS-485 converter). But usb-stick from AliExpress works better (react to
press on switch in HA faster).
Would you care to share your hassio config on the elfin and the configuration on the elfin itself with me?
Been trying to get it to work for hours, but nothing
@Silicon_Avatar, I wonder how you have installed the rs485 to tcpip converter. I am now gradually moving from Homeseer to HA so I’m really a newbie with HA. I have several programmable controllers with Modbus RTU interface. Each of these controllers is connected to a Moxa rs485/tcpip converter. I’m now wondering what is the recommended installation method for HA. I have installed HA onto a Win10 box using VirtualBox. How do you install the rs485/tcpip converter in HA?
