Since the new update you can add Energy monitoring.
I have added the electricity meter with a diy version of the slimmelezer.
I have a SMA solar inverter which is returning the daily yield.
learn more about statistics.
Homeassistat says that the entity is not configured correctly. Can i do something to configure it correctly or do i have to wait for an update?
Hi, Can you specify how to build a diy slimmelezer? I have found different schematics with Wemos D1’s converting the telegram to MQTT, but which to use to be compatible with ESPHomes DSMR?
