Is there a component that can show statistics and chart for energy usage of various z-wave devices i have in the house that shows energy used in total and by individual devices. I used the energy plugin in Vera and it show those information.
Also i clicked on one of the energy switch, its shows like this:
current power mwh 157967
it would be nice if its formatted to read better something like “211 watts”
The only interaction with the cloud is a message back to influx that they claim to use as a usage indication. You can configure influxdb not to send this though.
Sorry I didn’t get a chance to try it out yet, but will soon.
As you mentioned InfluxDB grabs data from HASS but does it integrate well in HASS to show graphs right on HASS UI or i have to use a different url to get to it?
InfluxDB is only a database specialized on storing sensor measurements.
It only does provide a CLI and a web UI for administrative tasks.
To visualize the data, you need a separate tool - I’m using Grafana.
Grafana has a “point and click” web UI that makes it very easy to create nice graphs from InfluxDB measurement data.
However, it does not integrate into HA, at least not out of the box, so you’ll access your graphs through the Grafana user interface.
You may be able to use panel_iframe: (or sth. similar) to get the Grafana UI into HA, but I didn’t get that working for my environment and gave up trying.
just looked at History Graph, and i don’t see anywhere options to change from what date range i want to graph and does it store data for ever? so i can review anything i want.
Question for Sebastian:
I am looking at InfluxDB also and the instructions for installation says about version -0.9.5.1
So i went to InfluxDB site to see whats the latest they have and notices “try it free for 14 days” does this mean its not a free application that i can install on raspberry (thats where my HASS is running)
thanks.
You can set the time range with the hours_to_show parameter. Data is stored in the home assistant database, as defined by “recorder” in your configuration.yaml. The history_graph is just extracting data from the database.
please ignore, i was not selecting the type: influxDB, now i was able to add datasource
Now, trying to create my first graph in the dashboard, and in the query looks like i have a learning curve to create one. for example i want to create a graph for my temperature sensor showing temperatures.
