I never got a response to this, but I also have an issue when manually operating any of my 3 Enerwave ZW500D switches. When I switch them on or off, HA still shows them on, but at some dim level.
This is the Z-Wave log when I turn the switch off manually:
2020-12-06 18:55:02.060 Detail, Node007, Received: 0x01, 0x0e, 0x00, 0x49, 0x84, 0x07, 0x08, 0x04, 0x11, 0x01, 0x26, 0x27, 0x70, 0x86, 0x72, 0xa2
2020-12-06 18:55:02.063 Detail,
2020-12-06 18:55:02.063 Info, Node007, UPDATE_STATE_NODE_INFO_RECEIVED from node 7
2020-12-06 18:55:02.063 Detail, Node007, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2020-12-06 18:55:02.063 Detail, Node007, QueryStage_Dynamic
2020-12-06 18:55:02.064 Detail, Node007, Queuing (Send) SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xc0, 0x21
2020-12-06 18:55:02.064 Detail, Node007, Queuing (Query) Query Stage Complete (Dynamic)
2020-12-06 18:55:02.064 Info, Node007, Sending (Send) message (Callback ID=0xc0, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xc0, 0x21
2020-12-06 18:55:02.072 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-06 18:55:02.072 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-06 18:55:02.111 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0xc0, 0x00, 0x00, 0x05, 0x2e
2020-12-06 18:55:02.111 Detail, Node007, ZW_SEND_DATA Request with callback ID 0xc0 received (expected 0xc0)
2020-12-06 18:55:02.111 Info, Node007, Request RTT 47 Average Request RTT 67
2020-12-06 18:55:02.111 Detail, Expected callbackId was received
2020-12-06 18:55:02.157 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x26, 0x03, 0x61, 0xb2
2020-12-06 18:55:02.157 Info, Node007, Response RTT 93 Average Response RTT 116
2020-12-06 18:55:02.157 Info, Node007, Received SwitchMultiLevel report: level=97
2020-12-06 18:55:02.157 Detail, Node007, Refreshed Value: old value=99, new value=97, type=byte
2020-12-06 18:55:02.157 Detail, Node007, Changes to this value are not verified
2020-12-06 18:55:02.157 Detail, Node007, Expected reply and command class was received
2020-12-06 18:55:02.158 Detail, Node007, Message transaction complete
2020-12-06 18:55:02.158 Detail, Node007, Removing current message
2020-12-06 18:55:02.158 Detail, Node007, Notification: ValueChanged
2020-12-06 18:55:02.175 Detail, Node007, Query Stage Complete (Dynamic)
2020-12-06 18:55:02.175 Detail, Node007, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2020-12-06 18:55:02.175 Detail, Node007, QueryStage_Configuration
2020-12-06 18:55:02.175 Detail, Node007, QueryStage_Complete
2020-12-06 18:55:02.175 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2020-12-06 18:55:02.175 Detail, Node007, Notification: NodeQueriesComplete
2020-12-06 18:55:05.164 Info, mgr, Refreshing node 7: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-12-06 18:55:05.165 Detail, Node007, Queuing (Send) SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xc1, 0x20
2020-12-06 18:55:05.165 Info, Node007, Sending (Send) message (Callback ID=0xc1, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xc1, 0x20
2020-12-06 18:55:05.174 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-06 18:55:05.174 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-06 18:55:05.212 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0xc1, 0x00, 0x00, 0x05, 0x2f
2020-12-06 18:55:05.212 Detail, Node007, ZW_SEND_DATA Request with callback ID 0xc1 received (expected 0xc1)
2020-12-06 18:55:05.212 Info, Node007, Request RTT 46 Average Request RTT 56
2020-12-06 18:55:05.212 Detail, Expected callbackId was received
2020-12-06 18:55:05.260 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x26, 0x03, 0x01, 0xd2
2020-12-06 18:55:05.260 Info, Node007, Response RTT 94 Average Response RTT 105
2020-12-06 18:55:05.260 Info, Node007, Received SwitchMultiLevel report: level=1
2020-12-06 18:55:05.260 Detail, Node007, Refreshed Value: old value=97, new value=1, type=byte
2020-12-06 18:55:05.260 Detail, Node007, Changes to this value are not verified
2020-12-06 18:55:05.260 Detail, Node007, Expected reply and command class was received
2020-12-06 18:55:05.260 Detail, Node007, Message transaction complete
2020-12-06 18:55:05.260 Detail, Node007, Removing current message
2020-12-06 18:55:05.261 Detail, Node007, Notification: ValueChanged
In the UI, it shows it on with a brightness of 1.
LIkewise, turning the switch on manually results in:
2020-12-06 18:58:02.884 Info, mgr, Refreshing node 7: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-12-06 18:58:02.885 Detail, Node007, Queuing (Send) SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xc3, 0x22
2020-12-06 18:58:02.885 Info, Node007, Sending (Send) message (Callback ID=0xc3, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x26, 0x02, 0x25, 0xc3, 0x22
2020-12-06 18:58:02.893 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-12-06 18:58:02.894 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2020-12-06 18:58:02.932 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0xc3, 0x00, 0x00, 0x05, 0x2d
2020-12-06 18:58:02.933 Detail, Node007, ZW_SEND_DATA Request with callback ID 0xc3 received (expected 0xc3)
2020-12-06 18:58:02.933 Info, Node007, Request RTT 47 Average Request RTT 49
2020-12-06 18:58:02.933 Detail, Expected callbackId was received
2020-12-06 18:58:02.979 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x26, 0x03, 0x56, 0x85
2020-12-06 18:58:02.979 Info, Node007, Response RTT 93 Average Response RTT 96
2020-12-06 18:58:02.979 Info, Node007, Received SwitchMultiLevel report: level=86
2020-12-06 18:58:02.979 Detail, Node007, Refreshed Value: old value=0, new value=86, type=byte
2020-12-06 18:58:02.980 Detail, Node007, Changes to this value are not verified
2020-12-06 18:58:02.980 Detail, Node007, Expected reply and command class was received
2020-12-06 18:58:02.980 Detail, Node007, Message transaction complete
2020-12-06 18:58:02.980 Detail, Node007, Removing current message
2020-12-06 18:58:02.980 Detail, Node007, Notification: ValueChanged
And the HA properties show a brightness of 87. It doesn’t matter if I had it set to full brightness before turning it off, it always comes back to 87 when manually turned on.
Is there something I can do to get manual operations to interact with HA correctly?
