I was just trying this car heater automation out as it sounds useful for the cold winter that is coming fast. I immediately ran into a problem. Both of the automations fail when HA tries to update them.
Update for sensor.car_heater_start_time fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 261, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 439, in async_device_update
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/template/sensor.py", line 238, in async_update
self._state = self._template.async_render()
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 215, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.7/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "", line 2, in top-level template code
TypeError: unsupported operand type(s) for -: 'NoneType' and 'float'
Update for sensor.car_heater_3h_before_start_time fails
File "", line 1, in top-level template code
TypeError: unsupported operand type(s) for -: 'NoneType' and 'int'´
Any idea what could be causing this?
