Engine heater package not firing
Hello!
I need help with this package, im sure it have todo with a breaking change in some version but i cant find out.
It has worked perfektly.
#  Package to manage your carheater at winter
# Packaged by @Naesstrom
# Original Repo : https://github.com/gribber/ha
# Required components etc.
#  - SMHI weather component (or any other weather component that gives a upcoming low value)
#  - Either a single device tracker for you or even better a group of trackers.
#----------- BINARY SENSOR -----------#
# We first need to be able to tell home-assistant if it's a workday (change country as needed)
binary_sensor:
  - platform: workday
    country: SE
#----------- SENSOR -----------#
# First off some sensors. required components is the SMHI weather addon.
# If you don't use that replace the correct sensors below to someone that you use.
  sensors:
    heater_departuretime:
      friendly_name: 'Departure time'
      value_template: '{% if states.input_number.heater_hour.state|round(0)|string|length == 1 %}0{% endif %}{{ states.input_number.heater_hour.state|round(0)|string }}:{% if states.input_number.heater_minute.state|round(0)|string|length == 1 %}0{% endif %}{{ states.input_number.heater_minute.state|round(0)|string }}'
    heater_activationtime:
      friendly_name: 'Calculated activation time'
      value_template: >-
        {% set atime = (states.sensor.heater_temptime.state|round(0) * 60) %}
        {% if states.input_number.heater_hour.state|round(0)|string|length == 1 %} {% set time = 0 %} {% endif %}
        {% set time = time|string + states.input_number.heater_hour.state|round(0)|string + ':' %}
        {% if states.input_number.heater_minute.state|round(0)|string|length == 1 %} {% set time = time|string + '0' %} {% endif %}
        {% set time = time|string + states.input_number.heater_minute.state|round(0)|string %}
        {{ (as_timestamp(now().strftime("%Y-%m-%d") + ' ' + time) - atime) | timestamp_custom("%H:%M")|string }}
    heater_temptime:
      friendly_name: 'Temperature adjusted time'
      value_template: >-
        {% set temp = states.sensor.heater_forecast.state|int %}
        {% if temp <= -15 %} {% set t = 1 %}
        {% elif temp > 5 %} {% set t = 20 %}
        {% else %} {% set t = (15 + temp) %} {% endif %}
        {{ (states.input_number.heater_maxmin.state|round(0)/(t**0.3))|int }}
    heater_forecast:
      friendly_name: 'Temperature forecast'
      value_template: >-
        {% if states.sensor.time.state < states.sensor.heater_departuretime.state and states.sensor.time.state > '00:00' %}
        {% set forecast = states.weather.smhi_home.attributes.forecast[0].templow %}
        {% else %}
        {% set forecast = states.weather.smhi_home.attributes.temperature %}
        {% endif %}
        {{ forecast }}
- platform: time_date
  display_options:
    - 'time'
#----------- AUTOMATION -----------#
# Here are the automations needed (make sure you replace relevant parts)
automation:
  - alias: "Engine heater activate"
      platform: template
      value_template: '{{ states.sensor.heater_activationtime.state == states.sensor.time.state }}'
    condition:
      condition: and
      conditions:
        - condition: state
          # replace entity_id below with your own tracker (group or single)
          entity_id: group.presence
          # if your home zone is called home
          state: home
        - condition: or
          # Below checks if it's a workday or not
          conditions:
            - condition: state
              entity_id: input_boolean.workdays_only
              state: 'off'
            - condition: and
              conditions:
                - condition: state
                  entity_id: binary_sensor.arbetsdag
                  state: 'on'
                - condition: state
                  state: 'on'
    # If the above conditions are fulfilled, ie. you are home and it's a workday
    # then activate the heater on your selected time
      - service: switch.turn_on
        # Don't forget to select the correct switch
        entity_id: switch.ac_0000005_16
  # Automation 2 turns off the car heater at the set delay.
  - alias: "Engine heater deactivate"
      platform: template
      value_template: '{{ states.sensor.heater_departuretime.state == states.sensor.time.state }}'
      - delay:
          minutes: "{{ states('input_number.heater_delay') | int }}"
      - service: switch.turn_off
#----------- INPUT BOOLEAN -----------#
# Creates a input boolean so that the heater is only active on workdays
input_boolean:
  workdays_only:
    name: Only active on workdays
    initial: true
#----------- INPUT NUMBER -----------#
# Input numbers to set the time
input_number:
  heater_hour:
    icon: mdi:timer
    initial: 06
    min: 0
    max: 23
    step: 1
  heater_minute:
    icon: mdi:timer
    initial: 25
    min: 0
    max: 55
    step: 5
  heater_delay:
    name: Time to overrun
    icon: mdi:timer
    initial: 30
    min: 0
    max: 59
    step: 1
    unit_of_measurement: min
  heater_maxmin:
    icon: mdi:timer
    initial: 120
    min: 30
    max: 240
    step: 10
#----------- GROUP -----------#
# Creates a group with all sensors, sliders etc.
group:
  engine_heater:
    # control: hidden
    entities:
      - sensor.heater_departuretime
      - sensor.heater_activationtime
      - sensor.heater_temptime
      - sensor.heater_forecast
      - input_number.heater_hour
      - input_number.heater_minute
      - input_number.heater_delay
      - input_number.heater_maxmin
      - input_boolean.workdays_only
      - switch.ac_0000005_16
#----------- CUSTOMIZE -----------#
# Just some small polishing moves!
homeassistant:
  customize:
    sensor.heater_forecast:
      unit_of_measurement: C
      icon: mdi:temperature-celsius
    sensor.heater_temptime:
      icon: mdi:timer
Where did you get the package?
You have given no logs or other symptoms of whatever problem you are seeing.
In the top is an adress for the package, its doing nothing…
A found a log could it be this:
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:71
Integration: template (documentation, issues)
First occurred: 6:00:27 (1 occurrences)
Last logged: 6:00:27
TemplateError(‘UndefinedError: ‘None’ has no attribute ‘attributes’’) while processing template ‘Template("{% if states.sensor.time.state < states.sensor.heater_departuretime.state and states.sensor.time.state > ‘00:00’ %} {% set forecast = states.weather.smhi_home.attributes.forecast[0].templow %} {% else %} {% set forecast = states.weather.smhi_home.attributes.temperature %} {% endif %} {{ forecast }}")’ for attribute ‘_state’ in entity ‘sensor.heater_forecast’
Found a never version in the adress, thanks anyway
