I need to enhance my YAML ESP32 EspHome configuration file bmssolar.yaml
(see the code below) with two functions (ideally, declared within the single existing YAML configuration file).
Context
My electricity provider only allows to feed in 4000W, and the inverter is also set to a feed-in power of 4000W. Therefore, I only want to charge the battery when the feed-in power reaches a value close to 4000W.
My battery charging current is a value read via Modbus „Netz-Leistung“ (“grid power”), and ranges from a minimum of 1A to a maximum of 25A. Currently, it is hardcoded in the YAML config file at 25.
Function 1
Variables:
- Be a global constant
feed_in_power_threshold
equal to4000W * 0.975
I want the Modbus „Netz-Leistung“ value to be periodically (every 30 seconds) compared with a decimal value equal to feed_in_power_threshold
While the Modbus „Netz-Leistung“ value is greater than the threshold, the variable should be increased by a delta 0.2A as long as it hasn’t reached the max constant value of 25A.
While the Modbus „Netz-Leistung“ value is less than the threshold, the variable should be decreased by a delta 0.2A as long as it hasn’t reached the min constant value of 1A.
I would also like to see the Modbus „Netz-Leistung“ value to be logged or printed out under ESPHome.
Function 2
Variables:
battery_soc_threshold
equal to80%
high_power_threshold
equal to4000W * 0.9875
low_power_threshold
equal to4000W * 0.875
The value read via Modbus „SOC“ should be periodically (every 30 seconds) compared with battery_soc_threshold
While the Modbus „SOC“ is greater than battery_soc_threshold
, then:
While the Modbus „Netz-Leistung“ is greater than a numeric
, a GPIO should be set to high (a consumer should switch on) and remain high for at least 10 minutes. No new control should be performed within that sleep time. -
While the Modbus „Netz-Leistung“ is less than a numeric
low_power_threshold
, the GPIO should go low (the consumer should switch off) and remain low for at least 5 minutes. No new control should be performed within that sleep time.
Particular wishes
The code should contain no so-called magic numbers. Any value should be declared as a global constant or a global variable with a meaningful name.
Ideally, I want it all to hold within the single existing YAML configuration file.
Error messages I am getting
Component not found: automation
Component template cannot be loaded via YAML (no CONFIG_SCHEMA)
YAML config file
substitutions:
max_cycles: "6000.0"
tx_pin: GPIO1
rx_pin: GPIO3
feed_in_power_threshold: !lambda '4000 * 0.975'
battery_soc_threshold: !lambda '4000 * 0.8'
high_power_threshold: !lambda '4000 * 0.9875'
low_power_threshold: !lambda '4000 * 0.875'
delta_charging_current: 0.2
max_charging_current: 25
min_charging_current: 1
esphome:
friendly_name: bmssolar
esp32:
board: esp32dev
framework:
type: arduino
logger:
baud_rate: 0
globals:
- id: can_420_rx
type: int
restore_value: "no"
initial_value: "0"
- id: charge_status
type: "std::string"
restore_value: "no"
initial_value: '"Startup"'
- id: charging_current
type: float
restore_value: "no"
initial_value: "25"
button:
- platform: restart
internal: true
wifi:
ssid: null
password: null
ap:
ssid: BmsSolar Fallback Hotspot
password: null
api:
encryption:
key: null
ota:
password: null
uart:
baud_rate: 9600
rx_buffer_size: 384
tx_pin: "${tx_pin}"
rx_pin: "${rx_pin}"
modbus:
uart_id: uart_0
send_wait_time: 900ms
modbus_controller:
address: 247
modbus_id: modbus0
command_throttle: 900ms
update_interval: 30s
output:
- platform: gpio
pin: 2
inverted: false
switch:
- platform: gpio
pin: GPIO4
- platform: modbus_controller
modbus_controller_id: bms0
address: 35140
register_type: holding
value_type: S_WORD
unit_of_measurement: W
device_class: energy
state_class: measurement
accuracy_decimals: 0
filters:
- multiply: 1
address: 37007
value_type: S_WORD
unit_of_measurement: "%"
filters:
- multiply: 1
address: 35174
value_type: S_WORD
unit_of_measurement: "°C"
device_class: temperature
filters:
- multiply: 1
template:
- sensor:
- name: "Charging Current"
unit_of_measurement: "A"
accuracy_decimals: 1
lambda: |-
float power = id(power_sensor).state;
float current = id(charging_current);
if (power > feed_in_power_threshold) {
if (current < max_charging_current) {
current += delta_charging_current;
} else if (power < feed_in_power_threshold) {
if (current > min_charging_current) {
current -= delta_charging_current;
id(charging_current) = current;
ESP_LOGD("charging_current", "Calculated charging current: %.1f", current);
return current;
automation:
- id: charge_control
alias: "Charge Control"
- platform: time
interval: 30s
- lambda: |-
float soc = id(soc_sensor).state;
if (soc > battery_soc_threshold && power > high_power_threshold) {
digitalWrite(GPIO_PIN, HIGH);
id(led).turn_on();
delay(600000); // 10 minutes in milliseconds
float new_power = id(power_sensor).state;
if (new_power < low_power_threshold) {
digitalWrite(GPIO_PIN, LOW);
id(led).turn_off();
delay(300000); // 5 minutes in milliseconds
} else {
id(led).turn_off();
