UPDATE
My Feature Request is unnecessary; the requested event already exists. It’s called:
event_template_reloaded
If you want your Trigger-based Template Sensors to compute their state value whenever Template Entities are reloaded, simply add the following Event Trigger:
- platform: event
event_type: event_template_reloaded
Without that, they are likely to report unknown until they are triggered.
Request
Create a new event that reports when Template Entities have finished loading. Then it could be used by Trigger-based Template Sensors to compute a value on loading (which is something non-Trigger-based Template Sensors already do).
- platform: event
event_type: template_entities_reloaded
Justification
I believe there is a small deficiency in the current behavior of Trigger-based Template Sensors: when first defined and loaded, their state value is unknown.
By design, a Trigger-based Template Sensor computes its state value only when one of its triggers fires. However, until that happens, its state is unknown.
I know of no way to mitigate this using currently available triggers. For example, this Trigger-based Template Sensor will report unknown until either the Time Pattern Trigger fires or Home Assistant is restarted.
template:
- trigger:
- platform: time_pattern
hours: '/1'
- platform: homeassistant
event: start
- name: Contrived Example
state: '{{ now() }}'
A seemingly obvious addition would be an Event Trigger that triggers when Template Entities are reloaded via call_service.
template:
- trigger:
- platform: event
event_type: call_service
event_data:
domain: template
service: reload
hours: '/1'
event: start
That should now trigger whenever Template Sensors are reloaded, right? Well no, because the Template Sensor can’t “hear” anything while it’s in the process of being reloaded.
It seems to me an event is needed to indicate when Template Entities have finished loading. Perhaps something that looked like this:
- platform: event
Then this configuration would ensure the Trigger-based Template Sensor reports a computed state value at the moment it is loaded.
template:
- trigger:
- platform: event
hours: '/1'
