First of all. This solution works, but i want to review it and enhance it a little bit.
There is a small problem, that i would like te resolve as well.
The animation that i use now:
alias: Sensor Gangpad On Off
description: ""
- platform: state
entity_id:
- switch.switch_tuinverlichting_sensor
to:
- "on"
- "off"
condition: []
- service: light.turn_{{ trigger.to_state.state }}
entity_id: light.dimmer_gangpad
- service: >-
{% if is_state('input_boolean.TuinVerlichtingForceOn', 'off') %}
light.turn_{{ trigger.to_state.state }} {% else %} light.turn_on {% endif %}
entity_id: switch.switch_tuinverlichting
mode: restart
- This automation triggers garden lights with a PIR sensor
- The switch is only turned of if Input_boolean is in state off
This code works, but cannot be maintained by the visual editor.
Is that posible?
Als i have one small issue.
Somehow the PIR sensor triggers the light.dimmer_gangpad on-command when it’s dark enough.
But it does not receive a off-trigger.
So i would like to set a maximum on-state to switch.switch_tuinverlichting_sensor.
If the switch is ‘on’ for more then 5 minutes, turn it ‘off’
Im not sure how to achieve this, without messing up how it works now.
Any ideas?
