Enigma2 receivers integration
I run Home Assistant OS 6.2 (Home Assistant Core 2021.8.8) in a virtual machine on my server.
I wanted to setup my enigma receiver. Since the custom_components folder did not exist I created it myself and put the files in as the readme says.
After putting the example code (ip & user/password changed to my data) in my configuration.yaml I get this error when checking the config:
Component error: enigma - Integration 'enigma' not found.
What am I doing wrong?
PS: the standard home assistant integration works fine
Hi @Alkahna
Do you have the folder created in the right place ?
Can you post a screenshot of your HA home folder structure ?
I don’t use HassOS, but I am sure it should load the custom components also
custom_components
├── enigma
│   ├── __init__.py
│   ├── media_player.py
│   └── notify.py
I’m pretty sure. As the custom_components folder did not exist I created it myself after reading somewhere about it.
Here is my folder structure:
Looks fine
Next step - can you restart and provide logs ?
There should be some warning or errors thrown
I did a reinstall of Home Assistant OS and now it is working fine. After putting all files in their place (had to create the custom_components folder myself) I put in the code in the configuration.yaml and then reboot the my Host (the VM which Home Assistant OS is running in) it was working.
However I#m mostly interested to use the power features On/Off and Stanby.
In the standard GUI Element there is only the power button which does On/Off to and from Idle mode. How can you do the deep standby or shut off?
What file would I need to copy/edit to make a more simple GUI element that only has the 3 power options (on from standby, off to standby and deep standby) and an indicator if the device is on or not?
Create control buttons by command line
Try this link contains commands for deep sleep and reboot.
i am already using the media-control card, but want also the source-list on this card. Is there chance to get it without clicking the three dots?
Has anyone an EPG-card? I search something, to see the program-guide and also to plan a recording…
Hi
Thanks for the hints.
The integration provides a media_player and notify platform.
The lovelace card used is the media-control, and it is restricted to the original elements.
The options is two create/develop a lovelace card that extends the media-control original elements.
I have no idea if it is possible to add more actions to the media_player platform, and make them available on the lovelace card.
I will need time to investigate that. Everything is possible, we just need time :slight_smile:
I didn’t copy anything into custom components. yet discovery allows me to find my enigma. (an entity not an integration)
Is the version found by discovery that of cinzas?
I would have liked not to write in my configuration.yaml the port nor the password. ( if I write them in secret.yaml it doesn’t work )
No it is not.
It is probably using the default enigma platform.
My version is slightly different, and it allows sending notifications to enigma.
Cheers
Hi to all from Germany!
Before I get really desperate, I’m asking here after having tried getting all this to work for a few days already.
I use a Vu+ Uno 4k and would like to integrate this into my HA.
What I have done:
  • Created a folder “enigma” in “custom_components”.
  • Put the files from Github in that very folder.
  • Restarted HA.
  • Opened configuration.yaml and inserted this:
#Enigma MediaPlayer
enigma:
    devices:
      - host: 192.168.178.74
        port: 80
        timeout: 20
        username: root
        password: xxxxxxx
        picon: picon
notify:
  - platform: enigma
    port: 80
    username: root
    password: xxxxxxx
When checking configuration, I get the following error:
Integration error: enigma - Integration ‘enigma’ not found.
Platform error notify.enigma - Integration ‘enigma’ not found.
What the hell am I missing here? I am feeling pretty stupid already for I simply don’t get this working…
THANKS for any help!
(the code I posted looks unformatted, but in my file it’s inserted correctly)
Yes, the yaml seems unformatted, are you sure it is correct ?
When restarting home-assistant, on the log file, do you see enigma platform being loaded ?
Something like this
2022-02-18 15:08:03 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration **enigma** which has not been tested by Home Assistant. This component might cause s
tability problems, be sure to disable it if you experience issues with Home Assistant
Do you see a message like this, or an error ?
THANKS for your quick reply.
My configuration looks like this (see screenshot).
2022-02-18 16_41_13-File editor – Home Assistant
When restarting HA, I see the following in the logfile and this is the only enigma-related point:
2022-02-18 16:01:08 ERROR (SyncWorker_2) [homeassistant.loader] Error parsing manifest.json file at /config/custom_components/enigma/manifest.json: Expecting value: line 7 column 1 (char 6)
However, it’s quite strange that my other custom components (HACS, HyperHDR) get a warning in the log just as you wrote above. Enigma does NOT (apart from the message above)
The configuration is not correctly indented.
You have 4 spaces, instead of 2, before devices.
Put like this.
#Enigma MediaPlayer
enigma:
  devices:
      port: 80
      timeout: 20
      username: root
      password: xxxxxxx
      picon: picon
notify:
  - platform: enigma
    port: 80
    username: root
    password: xxxxxxx
I need a little help please :slight_smile:
I have copied the enigma folder from the zip into my custom_components
this is how my configuration looks like
enigma:
  devices:
    - host: 192.168.178.62
      port: 80
      timeout: 20
      username: !secret enigma2_user
      password: !secret enigma2_password
      bouquet: '1:A7:A1:A0:A0:A0:A0:A0:A0:A0:AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet'
      picon: picon
notify:
  - platform: enigma
    port: 80
but after rebooting it doesn’t show up in my device or entity list. I have searched for enigma and dreambox but can’t find anything.
Thank you!
Hi @DirkStorck
The configuration looks good.
Can you restart HA and have a look to the log.
There must be some errors loading the custom_component.
Example from home_assistant.log
2022-04-21 14:18:52 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration enigma which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-04-21 14:20:12 INFO (MainThread) [homeassistant.setup] Setting up enigma
2022-04-21 14:20:12 INFO (MainThread) [custom_components.enigma] Initializing enigma devices
2022-04-21 14:20:12 INFO (MainThread) [homeassistant.setup] Setup of domain enigma took 0.0 seconds
2022-04-21 14:20:12 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.enigma
2022-04-21 14:20:12 INFO (MainThread) [homeassistant.components.notify] Setting up notify.enigma
Hi @cinzas
I have found this error after starting
2022-04-23 20:55:23 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 334, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp/_http_parser.pyx", line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'Invalid method encountered'"
2022-04-23 20:55:25 ERROR (MainThread) [homeassistant.components.media_player] enigma: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 431, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 735, in async_device_update
    await task
  File "/config/custom_components/enigma/media_player.py", line 205, in async_update
    pwstate = powerstate_soup.e2instandby.renderContents().decode('UTF8')
AttributeError: 'NoneType' object has no attribute 'renderContents'
Hi @DirkStorck
Don’t you have errors before ?
Remove the bouquet entry and see if it works (at least if it detects the device).
What OpenWebIf version are you running ?
Hi @cinzas ,
my WebInf-Version is 1.9
I have removed the bouquet and restarted HA I get these errors.
2022-04-25 12:56:06 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-04-25 12:56:18 ERROR (MainThread) [aiohttp.server] Error handling request
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.components.scene] Setup of scene platform homeassistant is taking over 10 seconds.
2022-04-25 12:56:31 ERROR (MainThread) [custom_components.xiaomi_miot_raw.deps.xiaomi_cloud_new] Timeout while loading MiCloud device list
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of tag is taking over 10 seconds.
2022-04-25 12:56:31 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2022-04-25 12:56:33 WARNING (MainThread) [homeassistant.config_entries] Config entry 'NINA' for nina integration not ready yet; Retrying in background
2022-04-25 12:56:35 WARNING (MainThread) [homeassistant.config_entries] Config entry '192.168.178.247' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2022-04-25 12:57:00 ERROR (MainThread) [homeassistant.components.media_player] enigma: Error on device update!
    await task
2022-04-25 12:57:18 ERROR (MainThread) [aiohttp.server] Error handling request
Hi
Ok, so you are receiving a HTPP 400 from the enigma box.
If you open this link via browser, http://192.168.178.62/web/getservices, using your user and password defined on HA, do you get a xml with the list of services on enigma2 ?
Which satellite box do you own, and which image are you running ?
You have openwebif 1.9 ? Isn’t 1.5 the latest version ?
