Add on simple remote for Enigma2 media player using command line
As an addon remote for my enigma2 media player by @cinzas . I get into difficulties pressing physical remote at times especially timeshift key and then fast forwarding through adverts(tiny buttons in the dark). There are loads more command keys.
The list down the left side are just on an entities card and don’t need pressed more than once. There may be a simpler way of making the grid momentary switches if anyone can comment.
configuration.yaml
   - platform: command_line
    switches:
      ok:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=352"'
        friendly_name: OK Press
      reboot:
        command_on: 'curl -k "http://192.168.0.5/web/powerstate?newstate=2"'
      shutdown:
        command_on: 'curl -k "http://192.168.0.5/web/powerstate?newstate=1"'
      timeshift:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=119"'
      play:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=207"'
      forward:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=208"'
      backward:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=168"'
      stoptimeshift:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=128"'
      up:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=103"'
      down:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=108"'
      left:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=105"'
      right:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=106"'
      exit:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=1"'
      info:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=358"'
      record:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=167"'
      menu:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=139"'
      epg:
        command_on: 'curl -k  "http://192.168.0.5/web/remotecontrol?command=365"'
I use grid card to put switches on but it makes them latching switches so need to turn them off when next press any tile on the grid so you can press up and up rather than pressing tile to move up then press it again to unlatch the switch before pressing it again to move up.
Automations.yaml
- id: '1628539728475'
  alias: enigma2 latching switches to off
  description: when command line switches turned on then get turned off fast to allow
    remote to work
  - platform: state
    entity_id: switch.down
    to: 'on'
  - platform: state
    entity_id: switch.up
    to: 'on'
  - platform: state
    entity_id: switch.right
    to: 'on'
  - platform: state
    entity_id: switch.left
    to: 'on'
  - platform: state
    entity_id: switch.info
    to: 'on'
  - platform: state
    entity_id: switch.exit
    to: 'on'
  - platform: state
    entity_id: switch.ok
    to: 'on'
  - platform: state
    entity_id: switch.menu
    to: 'on'
  - platform: state
    entity_id: switch.record
    to: 'on'
  condition: []
  - service: switch.turn_off
      entity_id:
      - switch.up
      - switch.down
      - switch.left
      - switch.right
      - switch.info
      - switch.exit
      - switch.ok
      - switch.menu
      - switch.record
  mode: single
