@philippk75 : Sorry, I don’t use Homekit. I don’t think that will work. @xus-droid: Then it won’t work, as it is designed to get the picon from webif directly, as a http request
@cinzas maybe with the repo-app than you set the device type to settop box or receiver, so also homekit would recognize ist as this device? the samsung app does so?
Unfortunately no. If the OpenwebIf team develops further on their API and starts giving more information, then yes, we will be able to add more sensors to this.
Currently, no temperature is given.
Have a look on templates also.
With this type of sensor you can then set automation for the usb fan also
Have a look on the Shell Command - Home Assistant
Apologies if this has already been answered. I have got my enigma2 set up on Home Assistant on a Raspberry Pi, I want to be able to use a voice assistant to go to a specific channel or channel up/down, volume up/down etc . I know I can use IFTTT , (that needs a HTTPS weblink) but I want to use a local voice assistant that only connects to my home network. I don’t know if anyone has experience setting up Rhasspy or similar to do this?
For example say I want change channel to Food Network by saying ‘computer (or whatever trigger word) Food Network’ and triggering this link:
http://root: password@box ip address/web/zap?sRef=1:0:1:B5E:7F3:2:11A0000:0:0:0:
Or can anyone who has successfully set up voice control to change channels etc guide me how?
Edit:
Ok after looking at lots of YouTube videos of using Rhasspy with Home Assistant I am a little bit closer to what I need to do, but would really need some help in integrating the media player. I am old and no experience of what to put into the yaml file to get it working. This video shows how Rhasspy works if anyone can point me in the right direction.
I’m trying to send notifications to my VuPlus receiver in my scripts but have a strange problem with data parameters messagetype. When I try to use messagetype as variable parameter filled via template then the notification never appears on screen.
Even a simple template like ‘"{{ 1 | string }}"’ doesn’t work for messagetype in my script.
I want to create universal notification script which sets messagetype parameter value via template.
It works for KODI notfications but it doesn’t for enigma.
Can’t get the messagetype parameter formatting right, have tried various combinations (of double quotes+apostrophes) but only static values like “1” works but no templates.
Its a long time ago (>2 years ago) when i used this great intergration.
I did bought a new enigma device (duo4K SE), so i was digging again in this intergration.
But i’m fighting with getting the picon vissible in HA with the intergration. If i set Picon to Screenshot function it is working. But i don’t get the picon in the intergration visible.
I do see the picon on my screen and in “openwebif” and also on the LCD screen
But i dont see it in the intergration in HA.
