Enocean battery-less wall switch - Single button light toggle and dimming
Hi, this is an automation blueprint for the Eoncean battery-less wall switches. It allows simple switching and dimming of lights with a single button. This makes it possible to control four different lights independently.
The automation consists of three phases: First, when a button is pressed, the entity is getting toggled (on or off). When the button is held down, the entity will be dimmed up by 5% every 200 milliseconds. After 20 iterations (dimming level at 100%) the entity is dimmed down by 5% every 200 milliseconds.
blueprint:
  name: Enocean Binary Switch
  description: Toggle and dim lights with one binary button
  domain: automation
  input:
    eonocean_id:
      name: ID of the Enocean Switch
      selector:
        text:
      description: Enter Eonocean ID in YAML Editor (eg [0x##, 0x##, 0x##, 0x##])
    topleft-target:
      name: Top-left target entity
      selector:
          entity:
            domain: light
    bottomleft-target:
      name: Bottom-left target entity
      selector:
          entity:
            domain: light
    topright-target:
      name: Top-right target entity
      selector:
          entity:
            domain: light
    bottomright-target:
      name: Bottom-right target entity
      selector:
          entity:
            domain: light
  # TOP-LEFT SWITCH
  - platform: event
    event_type: button_pressed
    event_data:
      id: !input eonocean_id
      pushed: 1
      which: 1
      onoff: 0
  - platform: event
    event_data:
      pushed: 0
      which: 1
      onoff: 0
    enabled: true
  # BOTTOM-LEFT SWITCH
  - platform: event
    event_data:
      pushed: 1
      which: 1
      onoff: 1
  - platform: event
    event_data:
      pushed: 0
      which: 1
      onoff: 1
    enabled: true
  # TOP-RIGHT SWITCH
  - platform: event
    event_data:
      pushed: 1
      which: 0
      onoff: 0
  - platform: event
    event_data:
      pushed: 0
      which: 0
      onoff: 0
    enabled: true
  # BOTTOM-RIGHT SWITCH
  - platform: event
    event_data:
      pushed: 1
      which: 0
      onoff: 1
  - platform: event
    event_data:
      pushed: 0
      which: 0
      onoff: 1
    enabled: true
condition: []
  - choose:
      # TOP-LEFT SWITCH
      - conditions:
          - condition: trigger
        sequence:
          - service: light.toggle
            data: {}
            target: !input topleft-target
          - delay:
              hours: 0
              minutes: 0
              seconds: 0
              milliseconds: 500
          - repeat:
              count: "20"
              sequence:
                - service: light.turn_on
                    brightness_step_pct: 5
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
          - repeat:
              count: "20"
              sequence:
                    brightness_step_pct: -5
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
      - conditions:
        sequence:
          - stop: ""
      - conditions:
        sequence:
            data: {}
            target: !input bottomleft-target
          - delay:
              hours: 0
              minutes: 0
              seconds: 0
              milliseconds: 500
          - repeat:
              count: "20"
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
          - repeat:
              count: "20"
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
      - conditions:
        sequence:
          - stop: ""
      # TOP-RIGHT SWITCH
      - conditions:
        sequence:
            data: {}
            target: !input topright-target
          - delay:
              hours: 0
              minutes: 0
              seconds: 0
              milliseconds: 500
          - repeat:
              count: "20"
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
          - repeat:
              count: "20"
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
      - conditions:
        sequence:
          - stop: ""
      - conditions:
        sequence:
            data: {}
            target: !input bottomright-target
          - delay:
              hours: 0
              minutes: 0
              seconds: 0
              milliseconds: 500
          - repeat:
              count: "20"
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
          - repeat:
              count: "20"
              sequence:
                - delay:
                    hours: 0
                    minutes: 0
                    seconds: 0
                    milliseconds: 200
      - conditions:
        sequence:
          - stop: ""
mode: restart
Unfortunately, it doesn’t seem to be possible to insert the Enocean ID correctly in the frontend, so you have to enter it in YAML (without quotes).
hello, i can’t make this work with HASSIO 2023.7.3 and PTM 215Z. Please can you share example of enocean id? i’m using the one found in z2m and the one purposed in automation when you create new one but seems not working.
