Hey there,
I got myself a NodOn 2 channel in wall module to play around a bit (SIN-2-2-0 - http://nodon.fr/en/enocean/enocean-in-wall-module-2-channels_13-1).
Although it is not listed under working components, at least the “sending part” of the device is working together with home assistant. It can be used similarly to a FT-55 switch. To clarify a bit what I mean by “sending part”: The NodOn in wall module allows to connect up to two switches (classical, non enocean ones) to it. Toggeling those switches will trigger the NodOn module to send enocean telegrams.
In order to receive those messages (e.g., via a USB300 stick), one has to introduce the NodOn module to home assistant via the configuration.yaml:
binary-switch:
- platform: enocean
hide: true
Within automation.yaml it can be used as follows:
- id: nodon_test
alias: NodON S1
platform: event
event_type: button_pressed
event_data:
id: [0xXX,0xXX,0xXX,0xXX] # id of the NodON switch
pushed: 1 # (a single rocker switch action will always trigger pushed 1 followed by pushed 0 - therefore, only filter for one event)
which: 1 # (1: channel S1, 0: channel S2)
onoff: 0 # (1: top, 0: bottom)
- service: light.toggle
entity_id: light.tradfri
So far I haven’t figured out, however, how to send telegrams to the NodOn module in order to switch the internal relay/actor.
According to the datasheet of the NodOn module, it’s also possible to change parameters/settings of the device via enocean telegrams (behaviour of the internal relay upon a switch action, for example). Does anyone know a command line tool which is able to set those parameters?
