Hi
In between I wrote some chaotic python spaghetti code.
It would be great if there is any python developer who is able to help me/us.
With the following python code I’m able to control my roller shutters by Home Assistant (Omnio UPJ230/12, sending EEP F6-02-02, receiving feedbak EEP D2-05-00). It shows the correct status (open, close, position) and I’m able to open and close them from Home Assistant.
The code uses again the kipe/enocean library and is based on the example code there.
Basically it’s also a Home Assistant -> MQTT -> Enocean gateway and vice versa.
It takes the sender ID of the enocean actuator and create the Home Assistant entities and the configuration of them by the Home Assistant MQTT discovery function. I only have to place the configured entities on the Home Assistant GUI from the “unused entities” list.
My USB enocean dongle sender IDs are teached in into the shutter actuator with the above described “teach in” script, and the actuator are configured sending periodically a feedback VLD telegram.
I also wrote the same chaotic python spaghetti code for enocean window contacts, light actuator and switch actuator. Maybe I should upload the scripts on GitHub, so that you can adjust and use it for your own application.
@Christianb233: Belong the data sheet of eltako FSB61NP you are only able to send commands to this roller shutter actuator, but not to receive state and position feedbacks?
Have fun with enocean and Home Assistant.
#/usr/local/bin/python3.7
# -*- encoding: utf-8 -*-
from enocean.consolelogger import init_logging
from enocean.communicators.serialcommunicator import SerialCommunicator
from enocean.protocol.packet import RadioPacket
from enocean.protocol.packet import Packet
from enocean.protocol.constants import PACKET, RORG
import enocean.utils
import traceback
import sys, time, queue, logging
import paho.mqtt.client as mqtt
mqttBroker = "10.0.0.99"
mqttUsername = "mqtt-user"
mqttPassword = "mqtt-secret"
mqttClientId = "enocean_gateway"
enocean_port="/dev/ttyUSB0"
# Pace your shutter ID and names here
rollo_actors = {'01:75:C9:FE' : 'rollo_nord'}
# or here, if open close is reversed, as the most of mines :-)
rollo_actors_v = {'01:77:30:3A' : 'rollo_west_1',
'01:75:BB:76' : 'rollo_west_2',
'01:72:60:48' : 'rollo_south_1',
'01:72:64:C0' : 'rollo_south_2'}
init_logging()
destination_id=[0xFF, 0xFF, 0xFF, 0xFF]
sender_id=[0xAA, 0xAA, 0xAA, 0x00]
def assemble_packet_press_a_1(sender_id):
return Packet.create(packet_type=PACKET.RADIO, rorg=0xF6, rorg_func=0x02, rorg_type=0x02,
destination=destination_id, sender=sender_id, R1=0, EB=1, R2=0, SA=0, T21=True, NU=True)
def assemble_packet_press_a_0(sender_id):
destination=destination_id, sender=sender_id, R1=1, EB=1, R2=0, SA=0, T21=True, NU=True)
def assemble_packet_press_b_1(sender_id):
destination=destination_id, sender=sender_id, R1=2, EB=1, R2=0, SA=0, T21=True, NU=True)
def assemble_packet_press_b_0(sender_id):
destination=destination_id, sender=sender_id, R1=3, EB=1, R2=0, SA=0, T21=True, NU=True)
def assemble_packet_release(sender_id):
destination=destination_id, sender=sender_id, R1=0, EB=0, R2=0, SA=0, T21=True, NU=False)
def on_mqtt_connect(client, userdata, flags, rc):
if rc==0:
print("Connection to "+mqttBroker+" successful, Returned code=",rc)
mqttclient.connected_flag=True
else:
print("Bad connection Returned code=",rc)
def on_mqtt_disconnect(client, userdata, rc):
print("disconnecting reason " +str(rc))
mqttclient.connected_flag=False
mqttclient.disconnected_flag=True
def on_mqtt_message(client, userdata, message):
print("Received Topic:",message.topic,"Message",message.payload)
if message.topic=="homeassistant/cover/enocean/rollo_west_1/set":
if message.payload.decode('UTF-8')=='OPEN':
communicator.send(assemble_packet_press_a_0([0xAA, 0xAA, 0xAA, 0x32])) #Teached in sender ID for this shutter
time.sleep(0.1)
communicator.send(assemble_packet_release())
if message.payload.decode('UTF-8')=='CLOSE':
communicator.send(assemble_packet_press_a_1([0xAA, 0xAA, 0xAA, 0x32]))
time.sleep(0.1)
if message.topic=="homeassistant/cover/enocean/rollo_west_2/set":
communicator.send(assemble_packet_press_a_0([0xAA, 0xAA, 0xAA, 0x35])) #Teached in sender ID for this shutter
time.sleep(0.1)
communicator.send(assemble_packet_press_a_1([0xAA, 0xAA, 0xAA, 0x35]))
time.sleep(0.1)
if message.topic=="homeassistant/cover/enocean/rollo_south_1/set":
communicator.send(assemble_packet_press_a_0([0xAA, 0xAA, 0xAA, 0x30])) #Teached in sender ID for this shutter
time.sleep(0.1)
communicator.send(assemble_packet_press_a_1([0xAA, 0xAA, 0xAA, 0x30]))
time.sleep(0.1)
if message.topic=="homeassistant/cover/enocean/rollo_south_2/set":
communicator.send(assemble_packet_press_a_0([0xAA, 0xAA, 0xAA, 0x34])) #Teached in sender ID for this shutter
time.sleep(0.1)
communicator.send(assemble_packet_press_a_1([0xAA, 0xAA, 0xAA, 0x34]))
time.sleep(0.1)
if message.topic=="homeassistant/cover/enocean/rollo_nord/set":
communicator.send(assemble_packet_press_a_1([0xAA, 0xAA, 0xAA, 0x33])) #Teached in sender ID for this shutter
time.sleep(0.1)
communicator.send(assemble_packet_press_a_0([0xAA, 0xAA, 0xAA, 0x33]))
time.sleep(0.1)
def connect_messages():
for k in rollo_actors:
mqttclient.publish("homeassistant/cover/enocean/"+rollo_actors[k]+"/config",'{"name" : "'+rollo_actors[k]+'", "device_class" : "shutter", "command_topic" : "homeassistant/cover/enocean/'+rollo_actors[k]+'/set", "set_position_topic" : "homeassistant/cover/enocean/'+rollo_actors[k]+'/set_position", "position_topic" : "homeassistant/cover/enocean/'+rollo_actors[k]+'/position", "uniq_id" : "'+k+'", "avty_t" : "homeassistant/cover/enocean/'+rollo_actors[k]+'/availability", "exp_aft" : "600"}', retain=True)
mqttclient.publish("homeassistant/cover/enocean/"+rollo_actors[k]+"/availability","online",retain=True)
mqttclient.subscribe([("homeassistant/cover/enocean/"+rollo_actors[k]+"/set", 0), ("homeassistant/cover/enocean/"+rollo_actors[k]+"/set_position", 0)])
for k in rollo_actors_v:
mqttclient.publish("homeassistant/cover/enocean/"+rollo_actors_v[k]+"/config",'{"name" : "'+rollo_actors_v[k]+'", "device_class" : "shutter", "command_topic" : "homeassistant/cover/enocean/'+rollo_actors_v[k]+'/set", "set_position_topic" : "homeassistant/cover/enocean/'+rollo_actors_v[k]+'/set_position", "position_topic" : "homeassistant/cover/enocean/'+rollo_actors_v[k]+'/position", "uniq_id" : "'+k+'", "avty_t" : "homeassistant/cover/enocean/'+rollo_actors_v[k]+'/availability", "exp_aft" : "600"}', retain=True)
mqttclient.publish("homeassistant/cover/enocean/"+rollo_actors_v[k]+"/availability","online",retain=True)
mqttclient.subscribe([("homeassistant/cover/enocean/"+rollo_actors_v[k]+"/set", 0), ("homeassistant/cover/enocean/"+rollo_actors_v[k]+"/set_position", 0)])
mqtt.Client.connected_flag=False
mqtt.Client.disconnected_flag=True
mqttclient = mqtt.Client(mqttClientId)
mqttclient.on_connect=on_mqtt_connect
mqttclient.on_disconnect=on_mqtt_disconnect
mqttclient.username_pw_set(username=mqttUsername,password=mqttPassword)
mqttclient.connect(mqttBroker)
mqttclient.loop_start()
mqttclient.on_message=on_mqtt_message
communicator = SerialCommunicator(enocean_port)
communicator.start()
# endless loop receiving radio packets
while communicator.is_alive():
if mqttclient.disconnected_flag:
connect_messages()
print("Connect Messages sent")
mqttclient.disconnected_flag=False
while not mqttclient.connected_flag:
print("Waiting for reconnect")
time.sleep(1)
try:
# Loop to empty the queue
packet = communicator.receive.get(block=True, timeout=1)
if packet.packet_type == PACKET.RADIO_ERP1 and packet.rorg == RORG.VLD:
packet.select_eep(0x05, 0x00)
packet.parse_eep()
if packet.sender_hex in rollo_actors_v:
#print("*** Got rollo feedback --> :", rollo_actors_v[packet.sender_hex], packet.parsed['POS']['raw_value'])
mqttclient.publish("homeassistant/cover/enocean/"+rollo_actors_v[packet.sender_hex]+"/position", 100-packet.parsed['POS']['raw_value'],retain=False)
elif packet.sender_hex in rollo_actors:
#print("*** Got rollo feedback --> :", rollo_actors[packet.sender_hex], packet.parsed['POS']['raw_value'])
mqttclient.publish("homeassistant/cover/enocean/"+rollo_actors[packet.sender_hex]+"/position", packet.parsed['POS']['raw_value'],retain=False)
else:
print("New unknown VLD telegram: ")
for k in packet.parsed:
print('%s: %s' % (k, packet.parsed[k]))
if packet.packet_type == PACKET.RADIO_ERP1 and packet.rorg == RORG.BS4:
print("New unknown BS4 telegram: ")
for k in packet.parse_eep(0x02, 0x05):
if packet.packet_type == PACKET.RADIO_ERP1 and packet.rorg == RORG.BS1:
packet.select_eep(0x00, 0x01)
packet.parse_eep()
print("New unknown BS1 telegram: ")
if packet.packet_type == PACKET.RADIO_ERP1 and packet.rorg == RORG.RPS:
packet.parse_eep(0x02, 0x02)
print("New unknown RPS telegram: ")
except queue.Empty:
continue
except KeyboardInterrupt:
break
except Exception:
traceback.print_exc(file=sys.stdout)
break
if communicator.is_alive():
communicator.stop()
print("Communicator stoped.")
mqttclient.loop_stop()
print("MQTT loop stoped")
mqttclient.disconnect()
print("MQTT client disconnected")
