Curious about this one, the following sensor:
sensor.envoy_<s/n>_current_battery_discharge
never goes to 0, or close to it. It appears to get ‘stuck’ at the last value when there’s no movement.
I’m inferring this for a few reasons, one the Enlighten web portal shows no volume in or out of the battery, and the available wattage never moves from the maximum after it’s at capacity.
Am I crazy? If I reset it to 0 manually, done as a test, it comes back to something like around ~400 watts output at all times. Even if the Enlighten app shows 100 watts ‘charging’.
For the time being, I’ve set the custom:power-flow-card-plus to use a Zero tolerance of 500 to get it to show ‘correctly’
Though I suspect there’s a ‘bug’ in that too, because it appears to add the battery discharge to the consumption reporting. I’ll have to look up if that’s intended, or if there’s a way to adjust it.
