Hi @mvana, Which specific HASS integration are you referring to?
There are many to choose from:
briancmpbll/home_assistant_custom_envoy
posixx/home_assistant_custom_envoy (archived on Jul 14, 2023)
jrutski/home_assistant_envoy_d7_fw
DanBeard/enphase_envoy
jesserizzo/envoy_reader
vincentwolsink/home_assistant_enphase_envoy_installer
Also, please advise what type of CT clamp setup you have.
Here is mine for example.
Mine is net-consumption = Load with solar production.
There are subtle differences behind the scenes about how this works
net-consumption = Load with solar production example:
total-consumption = Load only example:
Regardless of your CT clamp location and setting, the integrations that I have tried to understand the code of, all appear to get their data from:
https://envoy.local/production.json
which indicates to me that the Envoy does the required calculations every time that production.json file is requested and also provides a universal total-consumption figure regardless of your ct clamp setting.
For that reason, I can see why this data source is attractive for the developers of Enphase Integrations as it is 1 less variable to worry about.
In the above example, my house is consuming 1604 W and exporting 4482 W to the grid which is indicated by the - in front of the net-consumption number.
