Enphase Envoy - D7 firmware with JWT - A Different Approach
Ok, let me try tackle this issue for you.
I cannot guarantee the accuracy as my setup is not the same as yours, so sorry in advance if my solution is not perfect.
Step 1, How can I see what my system is currently setup as?
Go to https://envoy.local/ivp/meters/
look at the value of [1].measurementType
value: net-consumption = Load with solar production.
value: total-consumption = Load only
Step 2, show the difference between load only and net.
This is where things differ.
View the value of [1].activePower at the URL https://envoy.local/ivp/meters/readings
  • When set to total-consumption/(load only), this value will only ever be positive as it represents what the appliances in house are demanding/consuming.
  • When set to net-consumption/(load with solar production), you will either see a negative value to indicate power grid export or a positive value to indicate grid import as this value represents what is occurring at the utility/grid/meter.
Example of a user with total-consumption/(load only)
Step 3, what can we calculate with load only?
Source: /ivp/meters/readings Description W kW
value_json[0].activePower Power Production 2000 2.0
value_json[1].activePower Power Consumption 1337.395 1.33
template sensor calculation Power Net (Calculated) (consumption-production) -662.605 -0.66
template sensor calculation Power Export (Calculated) (production-consumption) 662.605 0.66
template sensor calculation Power Import (Calculated) (consumption-production) 0 0
The problem with load only setting is that the value for [1].actEnergyRcvd is empty at https://envoy.local/ivp/meters/readings.
The absense of that value causes the energy calculations to no longer be possible.
Source: /ivp/meters/readings Description Wh MWh
value_json[0].actEnergyDlvd Energy Production 609552.964 0.6
value_json[1].actEnergyDlvd Energy Consumption 447569.605 0.44
template sensor calculation Energy Export (Calculated) not possible
template sensor calculation Energy Net (Calculated) not possible
template sensor calculation Energy Import (Calculated) not possible
Step 4, How do we fill the gap for load only users?
Create the following sensors for Load Only installations.
rest:
  - headers:
      Authorization: !secret enphase_api
    verify_ssl: False
    scan_interval: 15
    resource: https://envoy.local/ivp/meters/readings
      - name: "Power Production"
        value_template: >
            {% set value = value_json[0].activePower | int(0) %}
            {% if value  <= 5 -%}
                0
            {% elif is_state('sun.sun','below_horizon') %}
                0
            {%- else -%}
                {{ value }}
            {%- endif %}
        device_class: power
        unit_of_measurement: W
        state_class: measurement
        icon: mdi:solar-panel
      - name: "Power Consumption"
        value_template: "{{ value_json[1].activePower | int(0) }}"
        device_class: power
        icon: mdi:home-lightning-bolt
      - name: "Energy Production"
        value_template: "{{ (value_json[0].actEnergyDlvd / 1000 | float(0)) | round(2) }}"
        device_class: energy
        unit_of_measurement: kWh
        state_class: total_increasing
      - name: "Energy Consumption"
        value_template: "{{ (value_json[1].actEnergyDlvd / 1000 | float(0)) | round(2) }}"
Then i added these template sensors to calculate power export and power import
template:
  - sensor:
        icon: mdi:transmission-tower
        device_class: power
        state : >
          {{ [0, states('sensor.power_production') | int(0) - states('sensor.power_consumption') | int(0) ] | max }}
  - sensor:
        device_class: power
        state : >
          {{ [0, states('sensor.power_consumption') | int(0) - states('sensor.power_production') | int(0) ] | max }}
  - sensor:
        device_class: power
        state : >
          {{ states('sensor.power_consumption') | int(0) - states('sensor.power_production') | int(0)  }}
And then finally, add these 2 sensors to convert:
power in W
to
energy in kWh
using https://www.home-assistant.io/integrations/integration/
  - platform: integration
    source: sensor.power_import
    unit_prefix: k
    unit_time: h
    method: left
    source: sensor.power_export
    unit_prefix: k
    unit_time: h
    method: left
I am unable to test this myself, so feel free to give it a go and let me know.
