I am currently fortunate enough to be on Software Version R5.0.55
People who had v7.x.x forced onto their systems automatically have now reported issues accessing information locally from http://envoy.local/
Once the device is on v7.x.x, there now suddenly seems to be an extra step required to access the information.
The extra step has something to do with generating a JSON Web Token (JWT) via https://entrez.enphaseenergy.com/
On that site, you can generate an uncommissioned token that expires after 7 days and that will allow you to access http://envoy.local/production.json
My apologies if this has already been covered, I haven’t had time to read the entire thread yet.
I just need a little help to polish my first automation. I have set up a LIFX RGBW bulb to emulate a Wattson, a simple device that shows the status of solar import/export by changing the colour of an LED. I’ve been able to find all the info I needed to set it up by searching this site and the HA documentation.
Except for one thing. How do I test for the Envoy being online? At the moment, if the Envoy drops comms with my IOT WLAN, the bulb just keeps the last state before comms dropped. This was highlighted yesterday with a sudden change of weather coinciding with the Envoy going offline. The bulb was showing bright blue, indicating export at >4kW, in the middle of a sudden heavy shower. IME that’s just not possible, so I looked at the Envoy’s web interface page and saw the comms were down.
What I’d like to do is have the automation switch the bulb to a distinctive scene (perhaps flashing alternating red and blue) when the Envoy’s data is unavailable.
I’m using the default Envoy integration.
By way of background:
I recently had additional panels added to my array, my Envoy was updated from the old Envoy R to an Envoy S with metering, and my solar generation was changed from single phase to 3 phase.
My old system had a Wattson attached, which used 5 CT clamps to measure 3 phase consumption and single phase generation. I had the additional 4 clamps required to measure 3 phase generation, but there wasn’t room in the meter box to add them. In fact with the Envoy S connections and the 5 existing CT clamps it was a struggle to put the front panel back in place. So the Wattson clamps had to be removed. We soon realised just how much we relied on the Wattson to help us schedule loads. It was so convenient having it in the kitchen, visible from the living room where we spend most of our time when we’re indoors.
You can then monitor the state of the entity binary_sensor.envoy for your automations. The problem with this is that you’re monitoring using the default Enphase integration and this isn’t real-time - I wrote some code to allow real-time monitoring of your Envoy locally and not depending upon the Enphase cloud. This only works if you have 5.x.x firmware in the Envoy - Enphase are in the process of upgrading every Envoy to the newest version 7.x.x which breaks this. Some have blocked internet access for the Envoy to ensure they don’t get upgraded to 7.x.x - I was unlucky and they upgraded mine so my code no longer works. if you have 5.x.x you may want to check it out as it gives readings every second and I have emulated the Watson in my dashboard cause the colour codes are very intuitive. GitHub - vk2him/Enphase-Envoy-mqtt-json: Takes real time stream from Enphase Envoy and publishes to mqtt broker
I work with a smappee. Works just like the Watson. It gives real time data and works perfect with HA. The only thing i need from the envoy is the load status off the enphase battery. That is why I keep trying.
followed every step and succeeded. .only problem : battery load is NOT included still thanks for helping {“system_id”:xxxxxxx,“modules”:19,“size_w”:4750,“current_power”:0,“energy_today”:0,“energy_lifetime”:18048343,“summary_date”:“2021-12-07”,“source”:“meter”,“status”:“power”,“operational_at”:1472819400,“last_report_at”:1638859821,“last_interval_end_at”:1638859793}* Connection #0 to host api.enphaseenergy.com left intact
Thanks @vk2him for the detailed response. I’ll have a look at your code after Christmas. I spent about a week and a half between HA, IFTTT, Node Red and Alexa trying to get something going from a total walk-up start to home automation generally.
Not to mention installation dramas, bouncing back and forth between attempted supervised and HA OS installations. Then finding that the RGBW globe I tried originally, a “white label” Tuya globe (Kogan, for other Aussies), required a major effort to configure the integration. I mean, having to sign up for a Developer account as well as an app account, then putting in BOTH pairs of credentials, only to be told that one (or more) was wrong, even though they were copied and pasted from the Tuya site. FFS!
I need to be doing other things for the next couple of weeks. So tuya-convert and MQTT can wait a while.
Happy wife, happy life.
So yes, I’m aware that the Enphase feed isn’t real-time, and I’ve seen references to your code before. But for now, I’ve got a working system that does enough to keep the wife happy. All she wants is a light that changes colour, without having to log on to a laptop or launch a phone app.
And my dashboard is PVOutput. I have generation back to Feb 2015 from Enphase. Consumption and nett for the last 3 or 4 years, since I found that my Wattson transmitter was readable by an OptiSmart gateway, which could supply a consumption feed to PVOutput. When the new Envoy went in, I just changed the consumption feed to Enphase. That’ll do me for now.
In due course I’ll go a bit deeper and set up a real time dashboard.
But between now and Christmas I have to set up a light show with HA and 24 Meross RGBW’s.
Did I mention that it’s a good idea to keep the wife happy?
Have you tried clicking this link http://envoy/production.json yet?
There is a storage section of that json file hosted on the Envoy.
Mine is blank as I don’t have a battery.
What sort of battery is it?
If you can see the battery status at https://enlighten.enphaseenergy.com/web/ there is a bunch of different methods you could try polling the cloud API.
Not a lot at the moment. I am realy new in HA. I have 2 CT’s one on the input of the electricity (verbruik) and one on the input of the solar panels 'opbrengst)(( 0 it is dark at the moment )
i am on the (hated) V7 envoy You remember) so I don’t think this is an option for me. I hav V5 so i could do all the local stuff. The installation guys for the battery updated my Envoy.
My point is, these 2 links are the graphical point and click version of the data you are trying to find in the api. If you go to these links and can see the battery level, then this is what will help you confirm that persisting with the API will work.
