UPDATE: It would appear my install is missing CT Clamps and my installer doesn’t know what those are so I’m working through it.
A check of the state of the 2 source sensors containing “current_power” in the name would have told you if your CT clamps were installed or not.
If it is in the middle of the day - you should see anything other than 0 for both numbers.
If it is in the middle of the night - production will be 0 or close to it but consumption will always return something other than 0.
I wonder if it would be better to do that on sensor :
template:
- sensor:
name: Grid Import Power
state_class: measurement
icon: mdi:transmission-tower
unit_of_measurement: W
device_class: power
state: >
{{ [0, states('sensor.envoy_SERIALNUMBER_current_power_consumption') | int(0) - states('sensor.envoy_SERIALNUMBER_current_power_production') | int(0) ] | max }}
- sensor:
name: Grid Export Power
device_class: power
state: >
{{ [0, states('sensor.envoy_SERIALNUMBER_current_power_production') | int(0) - states('sensor.envoy_SERIALNUMBER_current_power_consumption') | int(0) ] | max }}
I add default value to 0 for sensor.envoyXXX to prevent issue on restart of HA. Sometime I got reset to 0 of kWh productition/consumption and I thing it’s due to that.
New Enphase system was just connected and after having no luck with the built-in HA integration I read through this whole thread. Thank you for documenting all of this!
I installed the posixx integration, checked the box for Enlighten, and bam it seemed to be working! I was particularly interested in this comment:
This was especially interesting to me because my Enphase app is only showing production, the local page shows metering is not enabled, and my installer said I needed a CT clamp when I asked about it. However in Home Assistant I was able to see these entities with values (also all of the individual inverters show up w/ values):
This got me excited, and I was able to follow your guides to get Grid Import, Grid Export, etc sensors working. Values show 0 for the “Lifetime” and “Today” production/consumption sensors, but I figured since I have current_power_production I could just use this to convert to kWh with:
- platform: integration
name: Solar Production Energy
source: sensor.envoy_SERIAL_current_power_production
unit_prefix: k
unit_time: h
All of this gives me an energy dashboard that seemed to work at first, but I quickly realized something is very off. The consumption figure seems to roughly follow the production (or vice versa). They aren’t exactly the same, and it flips between import and export, but there’s no way my actual power use is following the solar curve this closely.
Pretty sure the current_power_consumption sensor is showing something other than my actual home consumption, I think the production sensor is semi accurate, but I can’t really tell.
I assume I just have to get the CT clamp installed and get metering enabled. When I do, do I check the “3-Phase” box when I set this up again?
Also are there any theories as to what my “current_power_consumption” sensor is showing? Because it definitely isn’t my homes power use.
When did you install the Posixx integration?
Worked like a charm over here, but since last week it stopped working. I receive a communicating with API error: Config entry ‘Envoy 122245084166’ for enphase_envoy integration not ready yet: Error communicating with API: All connection attempts failed; Retrying in background
After I put on my debug logging I can see the following warnings:
2023-06-10 13:25:45.458 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration enphase_envoy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-10 13:25:45.459 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-06-10 13:26:11.890 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Envoy 122245084166' for enphase_envoy integration not ready yet: Error communicating with API: All connection attempts failed; Retrying in background
2023-06-10 13:26:47.385 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: upnp
2023-06-10 13:27:27.843 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Compal Broadband Networks, Inc CH7465LG' for upnp integration not ready yet: Error connecting to device at location: http://[2001:1c03:5700:0:587:1221:c501:ae5]:5000/rootDesc.xml, err: ("UpnpConnectionTimeoutError('TimeoutError()', None)", None); Retrying in background
2023-06-10 13:30:11.250 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Envoy 122245084166' for enphase_envoy integration not ready yet: Error communicating with API: All connection attempts failed; Retrying in background
2023-06-10 13:50:32.178 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Envoy 122245084166' for enphase_envoy integration not ready yet: Error communicating with API: All connection attempts failed; Retrying in background
2023-06-10 13:52:27.690 DEBUG (MainThread) [custom_components.enphase_envoy.envoy_reader] Checking Token value:
2023-06-10 13:52:27.691 DEBUG (MainThread) [custom_components.enphase_envoy.envoy_reader] Found empty token:
2023-06-10 13:52:31.426 DEBUG (MainThread) [custom_components.enphase_envoy.envoy_reader] Commissioned Token valid for 364.9999950603589 days
Seems like a token is needed while this first wasn’t? On the other hand, it still works on your install is it?
I kept having this problem and it would require a reboot. I ended up turning off the “automatically add new entities” setting in the config options of integration so it would stop trying to auto-detect new settings like the IP address.
Notice that ipv6 url? Mine seemed to keep changing from ipv4 to ipv6 too. If you look on .storage, the stupid ip changes from the local to this due to zeroconf. Unfortunately I don’t have logs to show you but something to try.
Hi everyone,
I’ve been monitoring the home assistant and enphase forums, and it would seem a lot of people got their firmware automatically upgraded recently, myself included.
I looked at the code on a few integrations and noticed they all pulled data from https://envoy.local/production.json
From my testing of this URL, it can take anywhere from 400ms to 2000ms for the envoy to generate this json file. I suspect this may be due to the envoy having to perform some calculations every time this url is requested.
This caused me to look for alternatives which led me to https://envoy.local/ivp/meters/readings which from my testing takes on average 50ms to 70ms to respond and offers roughly similar data.
This is where I noticed another thread and decided to do some of my own tweaks.
Here is what I did to get my power sensors back on track.
I removed any existing enphase related integrations (native and/or HACS)
Added my 12 month token to /config/secrets.yaml
enphase_api: "Bearer 408CHARACTERJWT"
Then, back in /config/configuration.yaml, I added these 2 x CT clamp sensors
rest:
- headers:
Authorization: !secret enphase_api
verify_ssl: False
scan_interval: 15
resource: https://envoy.local/ivp/meters/readings
- name: "Power Production"
value_template: >
{% set value = value_json[0].activePower | int(0) %}
{% if value <= 5 -%}
0
{% elif is_state('sun.sun','below_horizon') %}
0
{%- else -%}
{{ value }}
{%- endif %}
device_class: power
icon: mdi:solar-panel
- name: "Power Net"
value_template: "{{ value_json[1].activePower | int(0) }}"
device_class: power
Then once I was happy with those 2 x CT clamp sensors updating every 15 seconds, I was able to use template sensors to do some calculations with them to get the other sensors I needed.
template:
- sensor:
name: Power Consumption
icon: mdi:home-lightning-bolt
device_class: power
state : >
{{ states('sensor.power_production') | int(0) + states('sensor.power_net') | int(0) }}
- sensor:
device_class: power
state : >
{{ [0, states('sensor.power_production') | int(0) - states('sensor.power_consumption') | int(0) ] | max }}
- sensor:
device_class: power
state : >
{{ [0, states('sensor.power_consumption') | int(0) - states('sensor.power_production') | int(0) ] | max }}
Now I have 5 sensors.
The only information currently being extracted from the envoy is the 2 ct clamp sensors power_production and power_net.
The other 3 sensors are template sensors where home assistant performs calculations when the 2 x CT clamp sensors get updated every X seconds.
Now I am able to have a dashboard like this that updates every 15 seconds.
Feel free to try smaller number refresh intervals for yourself if you want.
Or graphs like this
Here are the commands I manually used:
command:
curl -s -d 'user[email][email protected]&user[password]=MYPASSWORD' \
https://enlighten.enphaseenergy.com/login/login.json \
| jq -r .session_id
Result:
32CHARACTERSESSIONID
then I used my envoy serial number and that session ID in the next command to get my token.
curl -s 'https://enlighten.enphaseenergy.com/entrez-auth-token?serial_num=ENVOYSERIALNUMBER' \
-H 'cookie: _enlighten_4_session=32CHARACTERSESSIONID' \
| jq -r '.token'
Result:
408CHARACTERJWT
however this script is probably easier
As for anyone unsure of the length of time that the token is valid for, you can paste it into
https://jwt.io/
and it will decode the token and tell you the issue date and expiry date.
I have copy/paste your code but I have an error : Error fetching data: https://envoy.local/ivp/meters/readings failed with All connection attempts failed
The token works with CURL.
A common issue I’ve seen on other peoples issues is not putting “Bearer “ in front of the token in the secrets file.
Also, try using the ipv4 address rather than envoy.local just incase of dns issues
The ipv4 was the solution for me, thanks a lot !
I just got my Enphase system installed and came across this thread. When trying to implement it however, the Grid Import Energy always shows Unavailable and the Grid Import Power 0W
This is in my configuration.yaml file
- sensor:
device_class: power
state: >
{{ [0, states('sensor.envoy_xxx_current_power_consumption') | int(0) - states('sensor.envoy_xxx_current_power_production') | int(0) ] | max }}
- sensor:
device_class: power
state: >
{{ [0, states('sensor.envoy_xxx_current_power_production') | int(0) - states('sensor.envoy_xxx_current_power_consumption') | int(0) ] | max }}
name: Grid Import Energy
source: sensor.grid_import_power
unit_prefix: k
unit_time: h
method: left
name: Grid Export Energy
source: sensor.grid_export_power
unit_prefix: k
unit_time: h
method: left
When I look in the Developer Tools I can see the following values:
{{ [0, states('sensor.envoy_xxx_current_power_consumption') | int - states('sensor.envoy_xxx_current_power_production') | int ] | max }}
0
{{ [0, states('sensor.envoy_xxx_current_power_production') | int - states('sensor.envoy_xxx_current_power_consumption') | int ] | max }}
2686
{{ states('sensor.envoy_xxx_current_power_consumption') }}
717
{{ states('sensor.envoy_xxx_current_power_production') }}
3411
Any ideas?
I am using Enphase Envoy (DEV) as the integration and the system itself is on D7.0.88 (5580b1)
There are many possible reasons why this might be a problem.
The best start would be to go to /developer-tools/state
and type in this next to the magnifying glass icon under filter entities:
power_
My setup will look different to yours, but regardless of your integration, you should be able to see at least what your production and consumption sensors are reporting at that point in time.
So given the energy sensor uses the power sensor as the source, lets focus on what the power sensor is reporting first.
If it is in the middle of the day, and you are currently exporting power, then the power import sensor will be 0 (as mine also is right now as shown in the screenshot).
How long has this sensor been 0 for?
Using your own data we can see why:
The formula to record grid import breaks down like this:
if
consumption (717 W in your case)
minus
production (3411 W in your case)
0 or a negative figure (-2694 W in your case)
then
record 0 W
OMG. I am so stupid - I am currently not importing energy. Of course it is 0. Unbelievable. I was just confused because one of the sensor graphs (Grid Import Energy) says “unavailable” and that meant to me it is not working at all.
I still think I must be doing something wrong or not understanding:
This is what the Enphase app tells me:
but this is what Home Assistant shows:
kW = POWER live / right now / instantaneous
kWh = ENERGY over time (usually an hour/day)
If I turned on a device that consistently uses 1kW of power and left it running for an hour, it would use 1kWh of energy.
If I used that same device for only 30 mins, it would use 0.5 kWh of energy over 30 mins.
Okay cool. So the HA view is overall time for a specific date range set in the Energy dashboard.
Now I am wondering if there is a solution for HA to show the live state like Enphase does.
Yep, sure can
This is how I do it with the built in
type: horizontal-stack
cards:
- type: gauge
entity: sensor.power_consumption
severity:
red: 0
- type: gauge
entity: sensor.power_production
severity:
green: 1
