We have an Enphase system with solar and batteries and when looking at both their ‘Enlighten’ and (local) ‘Envoy’ interfaces, I can see and understand how the production, consumption and grid import/export work together. By that I mean that I can see that i.e. right now we’re producing 6.2kW, out of which 3.9kW go into the house’s consumption and 2.4kW to charge up the last 1-2% of the batteries AND because the production of 6.2kW does not fully cover the sum of those two (house+batteries) aka ‘consumption’, the system also imports a few watts from the grid.
In the official HA Enphase Envoy integration I can find the corresponding Production and Consumption sensors which seem to replicate 1:1 what the Envoy interface represents in the screenshot above. What’s missing however from the HA integration is that third metering category in the Envoy interface called ‘Net Power’ which provides what the system does with the grid side of things… import or export, see just a few seconds later:
Grid import/export values including net power and use with energy dashboard was added in HA 2024.3, provided you have net-consumption CT installed. When using a total-consumption CT some limitations apply and you would need to do some calculation. Without a consumption CT no data is available.
If a Storage CT is installed, battery charge / discharge values are available as of 2024.4. Without a storage CT, calculations are needed using the power or current battery capacity values.
Sorry to bump an old thread. Is there any plan to add grid consumption/export when using a total consumption CT? It seems the Envoy already does this calculation so it should be possible to grab those values. I’ve made my own helpers to do the calculation for using in automations (automatically adjusting the charge rate of my Emporia EVSE, adjusting HVAC temperatures, etc) but I can’t use these helpers in the energy dashboard.
As mentioned above and in the manual, there is no separate grid import and export values reported by the Envoy when using a total-consumption ct. The Envoy then reports positive or negative power for import or export. And when importing the measured net energy will go up and down when exporting.
What you have to do is create helpers that add positive energy changes of
sensor.envoy_sn_lifetime_balanced_net_energy_consumption
to a grid import entity and negative changes to a grid export entity. These can then be used in the energy dashboard. The manual has a skeleton example for this
